Old 03-01-2008, 01:03 AM   #1 (permalink)
Timeslip: 9.999 @ 101.32
Reputation: SUBY777 is on thin ice
Unhappy Whats Wrong???
install of headers uppipe downpipe and turbo inlet. i guess i didnt notice when i left the shop that there was a puddle of sometype of oil under the turbo inlet. i got home admiring the work when i noticed it. i thought it was not cleaned up from the install so i wiped it clean. i drove to the carwash and the puddle was back and dripping close to the crank pulley. what is that oil??? is it power steering fluid or engine oil?????? im worried now.
Old 03-01-2008, 10:26 AM   #2 (permalink)
if its red (ATF) then its power sterring fluid. if its oil, you most likely have a leaking head gasket. at my previous job I saw about 3-4 with the same symptoms and we replaced the head gaskets and the problem was solved.
Old 03-03-2008, 12:10 AM   #3 (permalink)
Talking Thanks
went to the track ran a 8.85 with no tune (running lean) and my clutch hating me(slipping).
ran the 4th race and my clutch gave out. still happy about the time though!! now i need fuel system upgrade clutch and tune. thanks for the recommendation about the gasket. ill get that changed asap.
Old 03-03-2008, 11:22 AM   #4 (permalink)
Car: 05 WRX
Reputation: Jcarv20 is an unknown
You ran an 8.85 in what?
Old 03-10-2008, 10:15 AM   #5 (permalink)
in a 1/8th @76.7
my clutch was slipping. i could feel it not pulling.i really need a tune and clutch.
