What would cause no cranking vacuum - Subaru WRX Forum: WRX Forums
» Auto Insurance
Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 11-27-2012, 01:57 PM   #1 (permalink)
Reputation: 02wrxrice is an unknown
Crank no start, has spark fuel and compression but no cranking vacuum. anyone have any idea what would cause this? the only thing ive heard is timing but after checking it everything seems fine. Cant figure this out, any and all advice is GREATLY APPRECIATED. thank you.
Offline   Reply With Quote
Old 11-27-2012, 04:26 PM   #2 (permalink)
Reputation: psinuse is known to be trustworthy and helpful psinuse is known to be trustworthy and helpful psinuse is known to be trustworthy and helpful
Are you sure it's getting spark, air and fuel? Do you smell gas after trying to start it?
________________
Resident Grumpy Old Man
03 SRP 2.34L
08' LGT Gears...
Old 11-28-2012, 10:08 AM   #3 (permalink)
i know for a fact its getting fuel, the spark plugs are covered in it after cranking. i tested for spark and it looks to be firing just fine. as for air like i said i have no vacuum but it does have compression on cylinder #1 at 135psi. I dont smell any gas either.
Old 11-28-2012, 02:16 PM   #4 (permalink)
Crank sensor. Try unplugging it and see what happens.
________________
03 SRP 2.34L
08' LGT Gears...
Old 11-29-2012, 08:25 AM   #5 (permalink)
I will try it tonight after work, but just out of curiosity what makes you say that?
Old 11-29-2012, 08:34 AM   #6 (permalink)
pzr2874's Avatar
Car: 2007 MazdaSpeed3
Club Region: Gulf Coast
Reputation: pzr2874 is known to be trustworthy and helpful pzr2874 is known to be trustworthy and helpful
the CPS goes out from time to time. He's probably just trying to eliminate things.
2007 XT
Old 11-29-2012, 10:00 AM   #7 (permalink)
i understand that, but i hooked up a scan tool and checked for a signal from the cps and it shows rpm.
