-   -   What would cause no cranking vacuum (http://www.wrxtuners.com/forums/f72/what-would-cause-no-cranking-vacuum-33319/)
02wrxrice 11-27-2012 01:57 PM
Crank no start, has spark fuel and compression but no cranking vacuum. anyone have any idea what would cause this? the only thing ive heard is timing but after checking it everything seems fine. Cant figure this out, any and all advice is GREATLY APPRECIATED. thank you.
psinuse 11-27-2012 04:26 PM
Are you sure it's getting spark, air and fuel? Do you smell gas after trying to start it?
02wrxrice 11-28-2012 10:08 AM
i know for a fact its getting fuel, the spark plugs are covered in it after cranking. i tested for spark and it looks to be firing just fine. as for air like i said i have no vacuum but it does have compression on cylinder #1 at 135psi. I dont smell any gas either.
psinuse 11-28-2012 02:16 PM
Crank sensor. Try unplugging it and see what happens.
02wrxrice 11-29-2012 08:25 AM
I will try it tonight after work, but just out of curiosity what makes you say that?
pzr2874 11-29-2012 08:34 AM
the CPS goes out from time to time. He's probably just trying to eliminate things.
02wrxrice 11-29-2012 10:00 AM
i understand that, but i hooked up a scan tool and checked for a signal from the cps and it shows rpm.
