-   -   What could cause high boost reading/bad gas mileage (http://www.wrxtuners.com/forums/f72/what-could-cause-high-boost-reading-bad-gas-mileage-33324/)
jimbo058 11-28-2012 02:44 PM
Monday morning while driving to work, I noticed my boost gauge was reading about 10-15 lbs of boost higher than normal. For example, when going up a slight hill, it usually reads minus-10 lbs on the gauge, and it was reading +5 lbs of boost.
The engine did not seem like it was laboring any harder than usual, but I burned about 2 times the usual amount of gas going to work and back. I was just driving along with traffic, not accelerating fast or anything. A 42-mile round trip, combination city-hwy.
The next day, it acted completely normal, with the boost gauge reading like it should and the gas mileage going back up to normal. Since then, I have reset the ECU and re-flashed.
Any ideas what would make it temporarily show way-higher boost and burn up twice the gas ? I eliminated things like parking brake engaged, foot on the brakes.
'09 WRX, Catback, Cobb Stage 1, no other power mods.
pzr2874 11-29-2012 06:45 AM
O2 sensor shittin the bed? You clean the MAF?
jimbo058 11-29-2012 12:25 PM
I religiously clean the MAF once a month. O2 sensor - that is a great idea. I saw one in the downpipe/midpipe area. Isn't there another one somewhere else ?
jimbo058 11-29-2012 12:40 PM
Found front O2 sensor on parts diagram !!! Answered my own question.
psinuse 11-29-2012 01:17 PM
Your over cleaning your MAF...
turmic 12-03-2012 10:23 AM
Keep your foot off the gas pedal.
pzr2874 12-03-2012 12:45 PM
Check your airbox.... mine keeps acting up. Just an idea.
jimbo058 12-03-2012 04:00 PM
Ok, I cleaned my air filter this weekend, and used air-filter sealing grease. I made sure the airbox was mounted correctly, with the two tabs inserted on the bottom, and two spring-hooks on the top. So far, so good. It ran great on the way to work this morning (Monday again already ... argggghhh !!)
