Weird ticking sound. - Subaru WRX Forum
post #1 of 9 Old 04-20-2011, 09:47 PM Thread Starter
08wrx1 is an unknown
Fist let me say that i Just got my 2008 wrx 3 weeks ago and have had to change the down pipe gastket allready.
once i did that i could here what sounded like waistgate flutter and now its more of a ticking sound with a faint whisleing sound this happens from -5 to 5 psi in boost. then after 5 it seem to stop but the car is loud with perrin down pipe and spt exhuast hopping its just an exhuast leak. hopping someone can help me out. and i have tride to reshearch this befor i posted. thanks
08wrx1 is offline
post #2 of 9 Old 04-20-2011, 10:04 PM
sounds like an exhaust leak
post #3 of 9 Old 04-21-2011, 06:41 AM
Post a video clip...
post #4 of 9 Old 04-21-2011, 03:56 PM Thread Starter
I'll try but dont think U would beagle to here it with all the other sounds.
08wrx1 is offline
post #5 of 9 Old 04-21-2011, 07:11 PM
wagonracer's Avatar
You mean all the barking
Sorry, I know what you meant to type....
wagonracer is offline
post #6 of 9 Old 04-25-2011, 12:24 AM Thread Starter
OK ya Bad spelling my bad trying to type while at work. UM so i made a video and u cant here the sound at all. so then i took my buddys 2005 sti stage 2 out and his made the same kind of sound just not as bad. still not sure what it is but both of are car boost fine and we couldnt fine any kind of leak. the only thing with mine is i have a down pipe with spt exhaust and junk injens intake and have had a po244 code come up twice. and as far as i no i dont have a tunem, but this week i have a AP coming with Perrin Intake.
08wrx1 is offline
post #7 of 9 Old 04-25-2011, 06:38 AM
Might be the injectors and cams. 5-40 Rotella should quiet it down a bit if that's what it is.
post #8 of 9 Old 04-26-2011, 11:33 PM Thread Starter
ok so iv been looking all over and think i have found what the problem is. found on Nasioc
"very faint ticking/Knocking sound low rpm under load.
Said to be BCS ticking or clicking. so if this is what it is how do i check for this and how can i fix it?
08wrx1 is offline
post #9 of 9 Old 04-27-2011, 06:33 AM
Is it coming from the BCS ? Find this out first. If it's the BCS, replace it.
If not, you won't hear it over the previously stated injectors and cams.
