weird sound at low revs, turbo? - Subaru WRX Forum
post #1 of 4 Old 09-04-2008, 07:02 AM Thread Starter
Post weird sound at low revs, turbo?
Hey everyone,
Had a VF34 installed bout 6 weeks ago, not long after i noticed a slight tinging sound sometimes at idle or initially as revs slowly build up (can't tell if it keeps happing after, too much noise) doesn't seem to be affecting anything but it is just playing on my mind any ideas or suggestings? I think its coming from the turbo but is too hard to pin point the sound.
Cheers
mello is offline
post #2 of 4 Old 09-04-2008, 07:40 AM
jrswrx69's Avatar
Send a message via Yahoo to jrswrx69
does the sound get louder the more rpm u have or does it go away the exhaust has the tab sound to begin with at the manifolds around the heads on mine it came stock with a vf 34
jrswrx69 is offline
post #3 of 4 Old 09-04-2008, 04:35 PM Thread Starter
After revs build up i cant hear it any more, if its idling or when im cruising and revs are really low thats only time i hear it. so its standard with vf34s?
I Know some1 in town that has a vf34 i should find out if his does the same, he has a 2litre tho.
mello is offline
post #4 of 4 Old 09-04-2008, 05:20 PM
jrswrx69's Avatar
subaru wrx has a nomal low tap to them even my buddys 02. its not the turbo tapping its valve clatter its nothing to worry about unless the sound gets louder with higher idle also check the turbo gasket for leaks and tighten it down that could be the noise to mine made it wen i changed my up&down pipes cuase gasket leaks
jrswrx69 is offline
