a way to refash - Subaru WRX Forum
post #1 of 5 Old 02-29-2004, 02:32 PM Thread Starter
vballshake is an unknown
a way to refash
I recently did the silencer removal and did a custom refab on the intake. I relocated my maf in the stock rubber tubing and a little bit back from where the air box was. Threw a cone filter and expected it to work fine. I started it up and it was having trouble idleing, and a cel popped up. I let it sit for awhile and it seemed like the computer was learning the new part. I disconnected the negative and the cel went away. Now every once in a while it will have trouble idleing at lights. Is there a way to like reset your computer so it can adjust properly? If not what would you suggest doing?
vballshake is offline
post #2 of 5 Old 02-29-2004, 04:27 PM
Tut4u2's Avatar
Images: 11
Tut4u2 is an unknown
Which intake did you buy for it? You cant just remove the MAF and 'relocate' it where ever.
Che
Tut4u2 is offline
post #3 of 5 Old 03-01-2004, 12:43 AM Thread Starter
I did a custom fab. I relocated it into the stock rubber tubing about 2 inches to the right. Would that really make that much of a difference? These freaking cars piss me off. I can't believe i got the cel just from moving the maf a tiny bit.
post #4 of 5 Old 03-01-2004, 03:30 PM
Tut4u2's Avatar
Images: 11
That might be it, because it probably isnt reading it right.
Che
Tut4u2 is offline
post #5 of 5 Old 03-20-2004, 10:06 AM Thread Starter
Do you think this will cause any problems in the future. I mean it runs well now, and isn't doing anything funny. I came to the conclusion that I relocated the maf too close to the throttle body and it is experiencing more air pressure than it is used to. If this becomes a problem I think I will just have to buy a cheap short ram off of E-bay.
