Wastegate Vacuum Line - Subaru WRX Forum
post #1 of 10 Old 02-23-2008, 10:39 AM Thread Starter
ScoobyRooWRX's Avatar
ScoobyRooWRX is an unknown
Angry Wastegate Vacuum Line
Ok, I have been having trouble with hitting stock boost for months now. I have stock airbox, hks cat back exhaust. and a BOV. I have been hitting 6 lbs of boost for months, sometimes I can hit nine when the car is cold but it will drop to 6 always. I checked for vacuum leaks and made sure all the hoses on the TMIC and turbo where on and snug. I felt the vacuum that goes to my stock waste gate and it broke right off like a cracker. It was to short to put the vacuum back on so I went to auto zone to get it replaced. On the way I gave it gas and I hot 14lbs boost strong, almost broke loose on the tires when it hit 14lbs. the engine light did come on but I was still pushing 14lbs. I reinstalled the new vacuum line to the wastegate and what do you know... im back at 6 lbs? !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
ScoobyRooWRX is offline
post #2 of 10 Old 02-23-2008, 11:52 AM
SWFL Scooby's Avatar
SWFL Scooby is an unknown
Did you check your vacuum hose to see if the restrictor pill is in there?
D-Rock
Under constant pressure
SWFL Scooby is offline
post #3 of 10 Old 02-23-2008, 12:21 PM
Longshot's Avatar
There's no creasing in the hose line at all right? And your connections are snug? ANd yes 1st make sure you can feel the pill (the side of the T that leads to the turbo, not wastegate).
DTRacing Tuned
Longshot is offline
post #4 of 10 Old 02-23-2008, 04:29 PM Thread Starter
Also, I don't want this to sound stupid but is it safe to leave the vacuum off the wastegate since im getting 14lbs great boost, no engine light now and no hesitation. I don't know if it is safe though to leave the line off the wastegate. It runs so much better when it is off.... with it on i'm at 6lbs. with it off i'm at 14lbs? just until I can afford to take it to the shop?
post #5 of 10 Old 02-24-2008, 09:02 AM
No it is not safe.Check the stock lines for the restrictor "pill".Should be a small brass restrictor in the line between the compressor housing to the "T".
dumdum is offline
post #6 of 10 Old 02-24-2008, 09:31 AM Thread Starter
does anyone have a pic of the restrictor pill? im looking at that tee but I dont see any sort if pill. im kinda new to this so bare with me. if someone can post a pic that would be great.
post #7 of 10 Old 02-24-2008, 09:41 AM
Strider327's Avatar
Strider327 is an unknown
Strider327 is offline
post #8 of 10 Old 02-24-2008, 09:53 AM Thread Starter
so that pill is inside the vacuum line that comes off of the tee to the turbo? how will i know if its bad? if it is missing thats my problem right? and if it is there?
post #9 of 10 Old 02-24-2008, 07:50 PM
If it is missing or has been tampered with (manually drilled), that's the problem. If it is fine, there is a different issue which I need more details about the car to guess at.
D-Rock
post #10 of 10 Old 02-25-2008, 12:51 PM
scuby_doo69 is an unknown
i had the same problem except my boost would surge... so i talked to my buddy who used to build sandrails with the 2.0 flat and we looked on how they had the vaccuum lines and they didnt run the line from the wastegate to the boost pressure sensor and so i just ran the line from the "t" back into the intake and avoided the sensor and it eliminated my problem and run a solid 14lbs
scuby_doo69 is offline
