Ok so I ran out of washer fluid. No big deal. Once I refilled it. Only one side was spraying. I thought that was odd. I then ran out of fluid again and now neither work. I can hear the motor working but the fluid just dribbles out. It won't spray. Could the lines be blocked or is it the motor?
If one side is working then it sounds like you have a leak. Check the lines from the pump (or both if you have a wagon), pull the line(s) off and test the pump(s), from there have fill it with water and have someone hold the button while you trae the lines under the hood until you find a leak or kink, if wagon then you'll have a harder time (I can't remember if the line run above the headliner or the roof rail). Start there and report back.
obvious question, but, are you using the correct fluid that won't freeze. That's why I asked... Occasionally, the most obvious answer is the correct one.
some winter washer fluid in canada is 40% methanol / 60% water :rocks:
doubles as WMI fluid.
