Violent shaking when i reach 4,000 rpm's. - Subaru WRX Forum
post #1 of 6 Old 05-19-2010, 09:53 PM Thread Starter
Colinmummery is an unknown
hey guys,
I've been having engine problems lately on my 02 WRX, when i reach 4,000 rpm's the entire car shakes very violently...any idea what this could be?? Also, when my boost reaches .05 there is a very high pitched whistling noise i have never heard before. if anyone knows what these problems could be please let me know ASAP. Thanks!!-Colin
Colinmummery is offline
post #2 of 6 Old 05-19-2010, 10:00 PM
Any more info? Does it still boost fully?? Does it still idle smooth?? have you checked for a leak in the vac / boost lines??
post #3 of 6 Old 05-19-2010, 10:10 PM Thread Starter
it idles smoothly, and it fully boosts. and sometimes i will let off the gas to reduce the shaking (do this for 2-3 seconds) and then hit the gas again and it will go past 4,000 without shaking. and i havent checked for leaks.
post #4 of 6 Old 05-20-2010, 08:58 AM
have you checked your motor mounts?
post #5 of 6 Old 05-20-2010, 09:07 AM
gunk007's Avatar
gunk007 is more helpful than not
This is probaly not the problems but have you checked your rims? dents, mud buildup? Otherwise I think Matt might be on to something. Good Luck!
gunk007 is offline
post #6 of 6 Old 06-14-2010, 09:24 PM
03stg2wrx's Avatar
03stg2wrx is an unknown
when you car shakes does continue to accelerate or does it cough and buck and backfire? If the high pitched whistling sound sounds like a squirrel getting its balls chopped off its your bpv gasket or I have also heard of that being a bad up pipe gasket, but I can speak from experience with the bad bpv gasket since I had mine on and off a million times and it will whistle like that in any sort of boost.
03stg2wrx is offline
