-   -   Valve cover gaskets (http://www.wrxtuners.com/forums/f72/valve-cover-gaskets-46825/)
justin93m 04-03-2014 08:32 AM
Valve cover gaskets
Could someone give me a run down on how to replace valve cover gaskets, i believe they are failing there is a ton of smoke coming from my turbo area and they were leaking before but it wasnt this bad, any help please
AllExtinct 04-03-2014 10:02 AM
You sure its coming from your valve covers? I know in the past I had smoke coming from my turbo area and it turned out to be my oil filter wasnt tightened enough so the oil was hitting the dp while I was driving and the smoke came up from behind the turbo area.
justin93m 04-03-2014 10:09 AM
ill double check that, there is oil on my downpipe, is there a little ring that should be in place ?
justin93m 04-03-2014 10:18 AM
ill start the car and drive for about 5 mins and then at stop lights i can see/smell burning oil. the downpipe has oil running down it and i cant really pinpoint were its coming from i havent jacked up the car, but i will this weekend
LW_Black4 04-03-2014 10:49 AM
Turbo is up top. Take a picture or 2 of where it's wet with oil and where the smoke is and post them.
justin93m 04-03-2014 10:51 AM
okay ill post them this evening! but thank you
sdunlimited 04-21-2014 07:55 PM
Any luck with those pics?
I get this too - typically not much if any visible smoke, but definitely burning oil smell at stop lights. Did the pass side VCG last spring and it didn't help (although, truth be told it may still be leaking a bit due to my sloppiness...)
I am finding that my oil filter housing seems to be leaking on the 'back side' (toward the exhaust). The filter will get a drop of oil on it and a streak down the side between changes. Not 100% sure where it's originating from yet but it's somewhere around there!
