Vacuum leak diag help! - Subaru WRX Forum
post #1 of 5 Old 12-17-2011, 05:44 PM Thread Starter
ejs0806 is more helpful than not
I think my car has a vaccum leak or at least 1 which i already know of... I grabbed a hose when i was trying to diag them and it was so dried out it completly snapped lol so have a few questions..
First how would i diag a boost leak or track em down..
Second what are the main areas to look around .
And third where would i go to by new lines?? The line that runs from my wastegate to right under the intercooler into some pipe theres a T off it that runs to under a black cover behind the intake is the one that completly broke so i need to get that but i would like to replace all the lines in that area just to prevent future problems. Could i just buy some sort of rubber hose that size in a roll somewhere?
ejs0806 is offline
post #2 of 5 Old 12-17-2011, 07:33 PM
http://www.cobbtuning.com/images_pro...stSystem_1.jpg
post #3 of 5 Old 12-18-2011, 02:15 AM Thread Starter
Yeah that's it where would I go to buy a bunch of that hose/tube??
ejs0806 is offline
post #4 of 5 Old 12-18-2011, 05:19 AM
wagonracer's Avatar
IMHO, do it right and get the correct parts from a dealership. Using the wrong ID hose, T's or missing the restrictor pill will mess up your boost levels. That being said, if you have a well stocked parts store nearby, you might be able to match everything up exactly. Just don't use any hose or connector that looks "close" and don't lose the pill
Cullen
wagonracer is offline
post #5 of 5 Old 12-18-2011, 07:23 PM Thread Starter
I don't need to replace anythinng before the T just the hose that connects to the T to the solenoid. Also I live down the street from checker/orielly so ill try there first because the nerest dealer is 40 min away
ejs0806 is offline
