utec reading - Subaru WRX Forum
post #1 of 15 Old 05-07-2004, 10:50 AM Thread Starter
Neef is an unknown
utec reading
My boost gauge reads 15 psi but sometimes my utec will read 20+psi and then will do a fuel shut off thing. My gauges I have never read 20+ psi. Whcih one would be right??? Why would my Utec read a higher boost level?
Thanks in advance.
Neef is offline
post #2 of 15 Old 05-07-2004, 11:00 AM
Narrus's Avatar
Narrus is an unknown
Send a message via Yahoo to Narrus
Stock boost gauge?
Narrus is offline
post #3 of 15 Old 05-07-2004, 12:28 PM
Cosmo's Avatar
Images: 15
The UTEC is correct. It is reading MAP and is cutting off because the UTEC's overboost fuel cut is at 20 psi.
Cosmo is offline
post #4 of 15 Old 05-07-2004, 01:16 PM
Narrus's Avatar
Yeah, oops. That was supposed to be, do you have a stock boost guage (reason being they are horribly inaccurate)? And as Cosmo stated, the UTEC would be correct.
Narrus is offline
post #5 of 15 Old 05-07-2004, 02:36 PM Thread Starter
Neef is an unknown
I have an autometer one and a omori or something like that. What is causing this? I do have an aftermarket intake. i also do have one screw missing from where you mount the MAP sensor to the intake. WOuld that make a difference?
Neef is offline
post #6 of 15 Old 05-07-2004, 03:08 PM
IBAUCLAPlaya's Avatar
Mechanical or electric autometer? The UTEC will be right because that is what IS controlling boost.
IBAUCLAPlaya is offline
post #7 of 15 Old 05-07-2004, 08:30 PM Thread Starter
Neef is an unknown
omori is electrical, and autometer is mechanical. omori reads about 2 psi higher than the autometer.
Neef is offline
post #8 of 15 Old 05-07-2004, 08:35 PM
Cosmo's Avatar
Images: 15
Your UTEC is right. Don't worry about the other gauges.
Cosmo is offline
post #9 of 15 Old 05-07-2004, 09:29 PM
T WREX's Avatar
T WREX is an unknown
Send a message via AIM to T WREX Send a message via Yahoo to T WREX
I hate to sound insensitive, but, have you had anything BUT problems with this car since you bought it? I feel bad for you.
FP Green'd 04 STi
Trevor
T WREX is offline
post #10 of 15 Old 05-07-2004, 11:14 PM Thread Starter
Neef is an unknown
nope, same problems ever since i bought the sti injectors. it was fine until i had them installed. Cosmo, would my aftermarket intake make the utec see more boost? Or possilby the missing screw that mounts it down? Right now its boosting and running real strong at 15 psi. But I want more power, 18 psi if i can and thats what I am trying to achieve.
Thanks
Neef is offline
post #11 of 15 Old 05-07-2004, 11:51 PM
Narrus's Avatar
You are getting more power if it's cutting out. That means you are hitting 20+ psi. Where are the gauges installed (well where are they reading from)? They should be fed off the hose on the side of the blowoff valve (I think).
Narrus is offline
post #12 of 15 Old 05-08-2004, 02:08 AM Thread Starter
Neef is an unknown
im not sure where they are installed, i will have to look at it. I dont really think my car is really going 20+psi because it doesnt feel like it.
Neef is offline
post #13 of 15 Old 05-08-2004, 09:09 AM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
Its possible that the UTEC could be wrong. To find out go buy a boost/vacuum meter (with peak) from Autozone (30-40 bucks, not the gauge kind) and tap into the vacuum line off the manifold or turbo with a vacuum hose T. This guage should give you the correct reading at idle, compair it to the UTEC. Now close the hood and do a quick first gear run, log the UTEC. Match the Peak hold on the meter versus the UTEC, there ya go. I've never seen the UTEC to be off more than 1/2 a psi without somebody previously messing with the calibration. Let me know
-kobi
Kobiyashi is offline
post #14 of 15 Old 05-08-2004, 09:18 AM
Cosmo's Avatar
Images: 15
One other thing you might want to check is the UTEC parameters. Make sure the UTEC boost display is set to "gauge" instead of "absolute".
Cosmo is offline
post #15 of 15 Old 05-08-2004, 01:21 PM Thread Starter
Neef is an unknown
cosmo how do i do that? if you tell me where to go in hyperlink I can do it. THanks for all the help guys.
Neef is offline
