Used ECU questions 06 WRX - Subaru WRX Forum
post #1 of 2 Old 09-02-2012, 10:43 PM Thread Starter
Front O2 sensor wires shorted on DP, fried the heater circuit on the ECU. I got a used ECU without the immobilizer or ignition.
-Is there a way to delete the vin programmed into the ECU or override it?
-If there is, do I have to unmarry the Accessport prior to old ecu removal?
-Should I just get a new ecu from the dealer and do I have to unmarry the AP then since its essentially the same ecu/vin?
Thanks
LBC_subie is offline
post #2 of 2 Old 09-02-2012, 11:47 PM
- No
- You should do it anyways because you need the original ECU in the car to unmarry it for use on the new ECU
