Urgent Help Needed! - Subaru WRX Forum
post #1 of 5 Old 04-16-2005, 04:26 PM Thread Starter
Urgent Help Needed!
I am calling out in desperation as I have a problem I cannot fix. I have just installed a new set of Pinks, (injectors) and one of them will NOT stop leaking. and when I say leaking I mean spraying. I have tried and tried and cannot fix it. I tried replacing it with one of the oem ones, it to now leaks, I put the injector on, rebolt the fuel rail and crank the car, and it jsut seems to unseat itself, and fuel sprays from between the rail and the injector, any ideas? please I am in dire sraights.
Scubyduby is offline
post #2 of 5 Old 04-16-2005, 06:39 PM
I'd double check and make sure the o rings are still on the injector. Other than that maybe the rail is bent and not seating on the injector all the way, although i think that would be very unlikely.
delswrx is offline
post #3 of 5 Old 04-17-2005, 01:08 PM Thread Starter
Yeah the o ring is there, I have come to the conclusion that it is the railbecause it does it no matter which injector I put in, so I ordered some aftermarket ones with overnight shipping, hopefully this will solve the problem.
post #4 of 5 Old 04-17-2005, 02:59 PM Thread Starter
Talking Found It!
ok, I went back out and just happened to look under the car, and see a rubber ring, not the little o ring mind you one much thicker and larger in diameter, so I pull the rail again and look into the openings where the injecors enter the manifold (not sure of the technical term) and that was where it went sure enough, stuck it back in, reattached the rail and vola, No leaks WOOT. Thanks for your reply!
post #5 of 5 Old 04-17-2005, 08:19 PM
no prob, glad you got it fixed.
delswrx is offline
