umm...... I realy don't know - Subaru WRX Forum
post #1 of 27 Old 04-28-2009, 10:06 AM Thread Starter
Danielson's Avatar
Danielson is an unknown
Well I've tried and tried and tried but I can't Find out what and where this noise is coming from! The sound only realy happen when it sits over night and I start it in the morning it idles rough and it sounds like a stuck lifter or something knocking in the engine and I can feel it in the Clutch, Brake and Gas pedels as I'm driving. The dealer which I Bought my Subie from is a Nissan/Carmax and the Techs could not mimic the sound or feel what I felt in the pedels. I've also installed the Group N Pitch Stop and thats the only mount I've install I have the Trans mount but haven't installed that yet. I've installed the Perrin Rear subframe Lock down Bolts subframe Bushings But have yet to install the diff bushings!
any advice?
2005 WRX
Borla XR-1 CBE Best Purchase so far
"Wax on wax off"
Danielson is offline
post #2 of 27 Old 04-28-2009, 01:52 PM
Have you tried a subie technician? I know carmax guarantees their cars for a weeks if i remember right, you could try asking them if a subie technician finds the problem if they cover it under the carmax guarantee or what not.
Unless it's been a while since you've had the car
post #3 of 27 Old 04-28-2009, 04:09 PM Thread Starter
Danielson's Avatar
Well I have had my subie for about four months and the Noise started last week my friend said I might need a tuneup or it could be a loose hanger or something to that efect and I have had it to car to replace my rear diff and they wouldn't touch it so they sent it to a Subaru dealer to replace the diff so they might do that for this but then again they might not. Also doesn't subaru say that when you install group N mount it incresses the Vibration?
2005 WRX
"Wax on wax off"
post #4 of 27 Old 04-28-2009, 05:58 PM
VD5505's Avatar
Not that much, If I were you I would go ahead and change out all the spark plugs and fuel filter and give a good look at everythere. When the car is running is the engine shaking around a lot while just sitting there? Does it also feel like you still have all the power when your getting on it?
VD5505 is offline
post #5 of 27 Old 04-28-2009, 11:33 PM
do you have the means to datalog?
post #6 of 27 Old 04-29-2009, 08:33 AM Thread Starter
Danielson's Avatar
the engine does shake but not crazy and i was planing on changing the spark plugs and fuel filter what type and brand would you guys recommend for our Subies and I dont have a datalogger if I get a datalogger that would tell me whats wrong or at least show me something to that effect? thanks for the help guys love this forum
2005 WRX
"Wax on wax off"
post #7 of 27 Old 04-29-2009, 12:56 PM
Oh oops, you said it happens at idle. So no need to datalog i guess unless it happens as you are driving as well and then idle rough at like a stoplight or something. Have you been keeping up with your scheduled maintenances? 30k, 60k service. You need to change your plugs at 60k if you are close to those miles yet.
post #8 of 27 Old 04-29-2009, 01:41 PM Thread Starter
Danielson's Avatar
Well it happens at idle and when im driving and most noticable in 3rd at 3,000-3,500.
4th and 5th you can barly feel it but once in 3rd and lower you really feel it!
2005 WRX
"Wax on wax off"
post #9 of 27 Old 04-29-2009, 01:47 PM
Can you still reach full boost? Have you tried to reset the ECU? Clean the MAF? When was the last time you replaced the plugs? Miles on the car? Mods?
post #10 of 27 Old 04-29-2009, 05:07 PM Thread Starter
Danielson's Avatar
I think I still reach full boost, How do I reset the ECU Noob question I know, And Mods are Perrin Panel Filter, Perrin AFTA MAF Tube, Snrokus air intake Delete, Stock BPV Replacing TurboXS type H BOV so glad I went back to stock, Group N Pitch Stop (dog Bone), Perrin Subframe Lockdown Kit (Diff mount bushings not installed), Not installed Group N Trans mount, Subaru braided Clutch line.
And the Miles are 52K
2005 WRX
"Wax on wax off"
post #11 of 27 Old 04-29-2009, 05:12 PM
VD5505's Avatar
Just take off your negative battery post for like 5 min or so, that is good that you went back to the stock bypass valve!!!
VD5505 is offline
post #12 of 27 Old 04-29-2009, 09:13 PM
03 CrazyTaxi's Avatar
Hope you still have the stock After MAF tube. You'll want to put that back on. A car that I worked on had one and it was causing a rough idle, strange readings from the MAF and a general hard time tuning it. After we put the stock one back in, reset the ecu, cleaned the MAF, car ran fine.
03 CrazyTaxi is offline
post #13 of 27 Old 04-30-2009, 08:28 AM Thread Starter
Danielson's Avatar
+1 Guys! I keep every Part I change except old bushings, Spark Plugs and so on.
Thanks for the help I'm gonna try the afta MAF tube replacement this weekend along with Spark plugs and fuel filter!
also what brand of spark plugs and fuel filter you guys run subaru or aftermarket?
2005 WRX
"Wax on wax off"
post #14 of 27 Old 04-30-2009, 06:55 PM
Plugs, I've been running NGK BKR7E. The only problem is these plugs were just discontinued by NGK... So I'm searching for a box of them.
post #15 of 27 Old 05-01-2009, 08:28 AM Thread Starter
Danielson's Avatar
I Reset my ECU last night and went for a drive there was a slight difference but not much then I looked at the MAF and DAM!!! That thing is Dirty I gonna pick up some cleaner on my way home today and somespark plugs and fuel filter.
2005 WRX
"Wax on wax off"
