it turns over but will not start? - Subaru WRX Forum
post #1 of 11 Old 10-07-2006, 06:07 PM Thread Starter
WRX_MOD_03's Avatar
WRX_MOD_03 is an unknown
OK, I have a 03 wrx and it turns over but will not start? I don't understand whats going on with it ? Can anyone help me?
WRX_MOD_03 is offline
post #2 of 11 Old 10-07-2006, 06:41 PM
bigbadbuddha's Avatar
Images: 15
Did your car just suddenly start doing this???? What brought this on???? Any CEL's
There could be alot of problems. We need some more info to help you out
Did you check and see that you are getting fuel??? Did you check and see that you were getting spark???
Big Jae -
JDM version 7 bugeye
bigbadbuddha is offline
post #3 of 11 Old 10-07-2006, 06:57 PM Thread Starter
WRX_MOD_03's Avatar
Well i am new to all this so i don't know how to check for spark on the wrx. I just put the motor in two days ago and its was pulled out to be rebuilt. So i have put in new spark plugs, I have checked over the wiring harness and it looks fine and hooked up right. The motors turns over nice but just doesn't want to fire up. No CEL's
post #4 of 11 Old 10-07-2006, 07:11 PM
Images: 15
Who did the engine work and install???
Big Jae -
post #5 of 11 Old 10-07-2006, 07:15 PM Thread Starter
WRX_MOD_03's Avatar
Well Subaru did the engine work and i install it and i was the one that pulled it.
post #6 of 11 Old 10-07-2006, 07:18 PM Thread Starter
WRX_MOD_03's Avatar
I know the motor is fine but i was thinkin that something wasn't hooked up right maybe? I am not sure just tryin th fix it, i am out of money so i cant take it in to get fixed
post #7 of 11 Old 10-07-2006, 11:28 PM
Black Night is an unknown
Send a message via AIM to Black Night
i had the same problem with mine, although idk if it is the same situation...i tried to start my car one day and all it did was crank and crank until a CEL popped up...it was crankshaft sensor mallfunction, basically it was telling me it wont start because it apparently is a severe problem...but i reset my ecu and let the car sit for a lil and didnt have the problem since
Black Night is offline
post #8 of 11 Old 10-08-2006, 01:46 AM
9d2TSi's Avatar
Something's not hooked up. Have them look it over again, or you can. Something's unplugged.
9d2TSi is offline
post #9 of 11 Old 10-08-2006, 07:18 AM
Check to see if the crankshaft sensor is even in.Its in front under the alternator.Very small and easy to miss.Do you have a repair manual?If not,get one quick.Do you have any buddies near by that know cars?On modern fuel injected cars it can be a millon things:fuel pump,fuel pump relay,sensors,ignition relay..... On my truck there was a lose connection on my oil pressure sensor.Well if the ECU doesn't see an oil pressure reading it won't let the injectors fire.I spent a butt load of hours trying to track down a fuel problem that had nothing to do with the fuel system.After about the 20th time of looking at the wiring diagrams i finally realized what was going on.
dumdum is offline
post #10 of 11 Old 10-08-2006, 11:04 AM Thread Starter
WRX_MOD_03's Avatar
Thanks Guys i got it runing, It was the crankshaft sensor wasn't hooked up. WOW! I can't believe i missed that LOL!Laugh!
post #11 of 11 Old 10-08-2006, 12:15 PM
yeaaa i knew it, glad to hear u got it running
