Turbo Whining noise - Subaru WRX Forum
post #1 of 6 Old 06-23-2010, 01:46 PM Thread Starter
Turbo Whining noise
at about 3500rpm the car seems to make a screaming/whining noise... not like a regular turbo whistle this actually scared me on the way to work... plus it only does it in the morning... not noticeable during the afternoon what should i do?!Cry!
turboner is offline
post #2 of 6 Old 06-23-2010, 07:11 PM
Hondafan's Avatar
You're sure it's the turbo? I had a power steering pump make what I would call a whine before. I think anything belt driven could have a problem like that at the pulley. If the turbo had an imperfection on the shaft it could squeal, in which case, it could be that. How are you on mileage? You may want to take it to the dealer in the case that it's the turbo. I wouldn't want to eat that cost on a car under warranty. They sometimes will, depending on the dealership, try to say that modifications were the cause of the failure (i.e. you put on a high flowing open downpipe which caused the car to spool the turbo more than it was designed to). Just be aware of that sort of stuff. Can you take a video of the sound or at least an audio clip? That always is beneficial in narrowing down sounds. Or if you can be really descriptive, like saying it sounds like finger nails down a chalkboard amplified 10 times. Sounds like really helps if you can't get an audio clip. Also, you can YouTube stuff and see what pulls up and see if anyone else has posted your issue before.
Hondafan is offline
post #3 of 6 Old 06-24-2010, 11:05 AM
03stg2wrx's Avatar
Is the whining just at 3500 rpm or does it continue from there on through the rev range?
03stg2wrx is offline
post #4 of 6 Old 09-29-2010, 10:58 AM
I just bought my WRX and it once in awhile will make this high pitched chirp. Im not sure if it's the turbo. It happens once in awhile and it sounds like a little bird almost but louder. Any ideas?
SoTWOLVERINE is offline
post #5 of 6 Old 09-29-2010, 10:59 AM
By the way the car has 111,xxx miles on it.
post #6 of 6 Old 10-01-2010, 11:18 PM
My 08 wrx(26k) makes a really weird whining noise around the same rpms, im convinced its the transmission. I can still hear the turbo its more of a whistle than a whine.
joystick is offline
