turbo timer problem - Subaru WRX Forum
post #1 of 9 Old 09-28-2004, 01:30 PM Thread Starter
shepswrx is an unknown
turbo timer problem
hope someone can help. have fitted a blitz FATT DC turbo timer with harness to my 2004 wrx but are having problems with the locking side of things. the whole idea of a turbo timer is to lock the car and walk away rite ? well i cant lock the car untill the timer has finished counting down thus defeating the object. any ideas.
shepswrx is offline
post #2 of 9 Old 09-28-2004, 02:07 PM
Cosmo's Avatar
Images: 15
Here's what you need to do:
1. Open the door
2. Push the lock button
That should work fine.
Cosmo is offline
post #3 of 9 Old 09-28-2004, 02:20 PM
bah14's Avatar
bah14 is an unknown
I had the same prob. with my wrx about a year ago ;-)
Cosmo,
Quick Q, the whole point of the HKS harness for the wrx is so that one can install a TT (say a blitz FATT DCIII) w/o any wire cutting/splicing what-so-ever, correct?
bah14 is offline
post #4 of 9 Old 09-28-2004, 02:40 PM
wrxzack's Avatar
wrxzack is an unknown
Subys won't lock with the remote if your key is in the ignition. With a turbo timer, your car still thinks there is a key in there so you have to lock it with the lock button.
wrxzack is offline
post #5 of 9 Old 09-28-2004, 05:19 PM
IBAUCLAPlaya's Avatar
You need to cut two wires to do that. One is in the keyless entry module right above the fusebox. It is a dark green wire with a black stripe. That allows the keyless remote to work while the car is running. The next is a grey wire in the security system module by the ebrake. That kills the shock sensor so your alarm doesn't go off when the car is running.
IBAUCLAPlaya is offline
post #6 of 9 Old 09-29-2004, 11:46 AM
tescrex's Avatar
tescrex is an unknown
Send a message via AIM to tescrex
So I have to chose between my shock sensor and a turbo timer? Thats lame.
tescrex is offline
post #7 of 9 Old 09-29-2004, 12:58 PM Thread Starter
so guys, as my car is new and still under warranty i dont realy want to start cutting wires or disabling the alarm features. is the any other options, mabe a different harness e.t.c
shepswrx is offline
post #8 of 9 Old 09-29-2004, 01:53 PM
Cosmo's Avatar
Images: 15
Or you can just lock the door with the power lock button as you are exiting the vehicle...
Once the motor stops running, the keyless entry will still work.
Cosmo is offline
post #9 of 9 Old 09-29-2004, 04:10 PM
But the shock sensor might go off depending on how your car idles.
