turbo quit me? - Subaru WRX Forum
post #1 of 19 Old 11-10-2008, 04:48 PM Thread Starter
dubrex2002's Avatar
dubrex2002 is an unknown
Send a message via AIM to dubrex2002
turbo quit me?
ok i was going down the road and was getting good steady boost 13.5 psi and everything was fine..i just installed my hid's and i parked it for 5-6 minutes tops..and got back in it and made it 200 feet from the parking spot not even getting out of first gear..i smelt something hot..cant really describe what it smelled like but i just smelt it for a second..and i pulled over b/c first thing i thought would be something with the Hid. and it looked like one was turned off from inside the car..but it was on..and after that i cannot hit boost..im getting good vacuum (17-18)...but no boost whatsoever..i couldnt hear the turbo spool up..i got home and got my fiance to rev it a lil and i could not hear the turbo idling down..(its straight piped TBE)..Every once in a while i have some fuel cut and it sounds like anti-lag..but it does it randomly..
2002 wrx 5spd
It has 94k miles
k&N drop in filter
Agency power Hardpipe turbo inlet
big 16G turbo
TBE no cats no muffler
Walbro 255lph fuel pump
dubrex2002 is offline
post #2 of 19 Old 11-10-2008, 04:57 PM
03 CrazyTaxi's Avatar
wastegate issue?
03 CrazyTaxi is offline
post #3 of 19 Old 11-10-2008, 06:33 PM
Who tuned it? How are you measuring boost?
post #4 of 19 Old 11-10-2008, 06:33 PM
Hope with the rest of those mods....you managed to swap out the up-pipe. Because sucking up the cat would be horrible. I don't understand how you have psi, but you say you have no boost.
post #5 of 19 Old 11-11-2008, 08:43 AM
awdturb is an unknown
the excess heat and no boost sounds like a up pipe frag. could be a nice chunk sitting in the exhaust housing blocking up the flow and making a ton of heat due to the restricted flow. do you have a EGT gauge?
awdturb is offline
post #6 of 19 Old 11-11-2008, 05:07 PM Thread Starter
dubrex2002's Avatar
i do have a spare waste gate i will try that first as soon as it cools off..i just got home
post #7 of 19 Old 11-11-2008, 05:15 PM
A... spare... wastegate? You mean the actuator? The wastegate itself is internal to your turbo and no exactly replaceable on it's own...
You didn't answer my questions:
post #8 of 19 Old 11-11-2008, 05:48 PM
SuBeast's Avatar
SuBeast is on thin ice
Possibly his cat got sucked into the turbo...
He probably has some boost gauge...
FAST
RELIABLE
CHEAP
Pick 2
2006 STi
1990 Toyota Hilux - daily
SuBeast is offline
post #9 of 19 Old 11-11-2008, 07:52 PM
Everybody has been waiting for this to happen again.... It's like a horror movie silent part right before you crap your pants.
Does he have EM ?
post #10 of 19 Old 11-11-2008, 08:06 PM Thread Starter
dubrex2002's Avatar
boost gauge..no EM..yes i meant the actuator
post #11 of 19 Old 11-11-2008, 09:03 PM
sfelix818 is more helpful than not
You have a 16g turbo, no EM...... Did you have your car tuned for the 16g turbo??
sfelix818 is offline
post #12 of 19 Old 11-11-2008, 09:20 PM Thread Starter
dubrex2002's Avatar
no..it hasnt seen much more than 4k rpms..ive been easy on it until i can get it tuned
post #13 of 19 Old 11-11-2008, 09:21 PM Thread Starter
dubrex2002's Avatar
i shift around 2-3k..cant afford to go further..lol
post #14 of 19 Old 11-11-2008, 10:04 PM
if ## not hitting boost, turbo isnt spooling, if ## turbo isnt spooling something has lodged itself in ## turbo turbine fins. all that hot exhaust build up is what u smelt most likely (you probably know this already) go get it checked out or check it urself. if all the fins are effed then its time to upgrade the turbo and get a new up pipe...just in case.
srninjastar is offline
post #15 of 19 Old 11-11-2008, 10:22 PM
That's your first problem. Second one is like srninjastar said, you probably are going to need a new turbo.
