Go Back   Subaru WRX Forum: WRX Forums > WRX Tech Forums > Problem Diagnosis
Old 06-17-2009, 06:34 PM   #1 (permalink)
Car: 04 WRX
Reputation: Coastiedan is an unknown
Turbo oil inlet problem
My turbo inlet oil line keeps leaking oil every 5 months. which I replaced one in jan, and now its smoking and leaking once again. my buddy thinks its a pressure problem, since i have my cobb tuner set to fuel efficient. Which my boost is set really low. Its not rubbing either so i dont know. About to get my new line here soon, and then turn my boost back up. Does anyone have any other suggestions, on what it could be? I had my engine block replaced a two years ago, is anyone think that my be it also? Thanks for your help
Old 06-17-2009, 06:52 PM   #2 (permalink)
Any mods to the car other than an AP?
Old 06-17-2009, 10:06 PM   #3 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi is known to be trustworthy and helpful 03 CrazyTaxi is known to be trustworthy and helpful
Kinda confused as to what exactly is going on...
Old 06-17-2009, 11:03 PM   #4 (permalink)
Timeslip: 9.999 @ 101.26
Where exactly is it leaking from? Is it by where the bolt to hold the line down is or where the hose connects to the piping?
Old 06-18-2009, 12:33 AM   #5 (permalink)
Car: 04 WRX
The only other mod i have is a full 3 in exhaust. its leaking where the oil line connects to the turbo. right above the bolt. so its not a loose bolt.
Old 06-18-2009, 06:53 PM   #6 (permalink)
I would first try and replacing the bolt and the washer with it. Im sure you can just order the part at a local subaru dealership or see if a local car parts store has it.
I believe this is what it is.
Photobucket
Old 06-19-2009, 03:36 PM   #7 (permalink)
Car: 04 WRX
Well i put the new line on today, and put my boost back up. It looks something like that. But i guess ill see in 5 months if it breaks again. When i was putting it on i noticed that the bracket for the line was bending the line so i turned it around and theres alot less bending on the line itself. Thanks for all your help
Old 01-17-2010, 06:01 PM   #8 (permalink)
Car: volvo 850R
Reputation: busadave is an unknown
i also believe theres a recall for just that problem,new line and bracket
Old 01-17-2010, 07:58 PM   #9 (permalink)
Reputation: turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful turmic is known to be trustworthy and helpful
Care to reference the TSB?
CBRD SpeedFactory Protuned 266 whp/315 wtq corrected 06 STI
