-   -   Turbo oil inlet problem (http://www.wrxtuners.com/forums/f72/turbo-oil-inlet-problem-26459/)
Coastiedan 06-17-2009 07:34 PM
My turbo inlet oil line keeps leaking oil every 5 months. which I replaced one in jan, and now its smoking and leaking once again. my buddy thinks its a pressure problem, since i have my cobb tuner set to fuel efficient. Which my boost is set really low. Its not rubbing either so i dont know. About to get my new line here soon, and then turn my boost back up. Does anyone have any other suggestions, on what it could be? I had my engine block replaced a two years ago, is anyone think that my be it also? Thanks for your help
newtothegame 06-17-2009 07:52 PM
Any mods to the car other than an AP?
03 CrazyTaxi 06-17-2009 11:06 PM
Kinda confused as to what exactly is going on...
baller_v24 06-18-2009 12:03 AM
Where exactly is it leaking from? Is it by where the bolt to hold the line down is or where the hose connects to the piping?
Coastiedan 06-18-2009 01:33 AM
The only other mod i have is a full 3 in exhaust. its leaking where the oil line connects to the turbo. right above the bolt. so its not a loose bolt.
baller_v24 06-18-2009 07:53 PM
I would first try and replacing the bolt and the washer with it. Im sure you can just order the part at a local subaru dealership or see if a local car parts store has it.
I believe this is what it is.
<a href="http://s193.photobucket.com/albums/z85/baller_v24/?action=view&current=Union20bolt20and20washer20part20num.jpg" target="_blank"><img src="http://i193.photobucket.com/albums/z85/baller_v24/Union20bolt20and20washer20part20num.jpg" border="0" alt="Photobucket"></a>
Coastiedan 06-19-2009 04:36 PM
Well i put the new line on today, and put my boost back up. It looks something like that. But i guess ill see in 5 months if it breaks again. When i was putting it on i noticed that the bracket for the line was bending the line so i turned it around and theres alot less bending on the line itself. Thanks for all your help
busadave 01-17-2010 07:01 PM
i also believe theres a recall for just that problem,new line and bracket
turmic 01-17-2010 08:58 PM
Care to reference the TSB?
