turbo - Subaru WRX Forum
post #1 of 5 Old 07-19-2011, 01:36 AM Thread Starter
Post turbo
my turbo is not spining up and boosting like it usta to the point of basicly no power when i want it, i mean my baby gots almost 200,000 miles on her... she diserves to act up a bit. but i have never worked on turbos i pulled rebuild and replace many egines so im not a newbie i just dont know anything about turbos ecept how they kind work. i need some help anybody.
WashingtonZephyr is offline
post #2 of 5 Old 07-19-2011, 05:36 AM
What are you using to measure boost ?
Any CEL's ?
Is it the original snail in there ?
post #3 of 5 Old 07-20-2011, 12:03 AM Thread Starter
yeah its the original, there is a gauge in the car but its not psi, it reads MPa's i havnt figured out what that is either figured its metric or something.. when the car was running real well the gauge would read just alittle over 1 MPa, now it wont get over .05 MPa. and it will go into the negitive numbers when you let off the peddle. Also im working on getting the codes cleared, just replace the O2 sensor, and working on an exhaust code with a leak, but i was also wandeing if there is any codes or will the computer pull up a code for something wrong with the turbo....
post #4 of 5 Old 07-20-2011, 05:13 AM
Sure that isn't .1 MPa and .05 MPa? Cause 1 MPa is 140psi.
post #5 of 5 Old 07-20-2011, 05:43 AM
^^ Keith is right, use this tool/link. You mean .10 MPa and .05 MPa
.10 is about right for a stock 02 WRX. Negative is vacuum (normal)
The ECU will not really give you a code specifically for the turbo going but throws codes for overboosting/fuel cut/etc..etc..
Get the codes read and rule out a boost leak. What have you played with under the hood as of late?
One of the common areas for boost leaks is the elbow from the turbo to the TMIC.
2-The turbo inlet hose itself (If it's cracked/torn which happens all the time because they become brittle after a couple years).
3-And the BPV gasket to the TMIC.
Post up your findings.
Kilopascal [kPa] To Psi [psi] Converter
