Tumbler valves both stuck open? - Subaru WRX Forum
post #1 of 5 Old 11-17-2011, 01:58 PM Thread Starter
I started my car this morning.. it was cold it took a bit longer to start than normal. the CEL came on. I checked it at work P1090 P1092 and P1095 Tumbler valve stuck open and high current or something. both sides though simultaneously. then i checked my battery cuase it started hard.. .good checked my alt bad.... so i am getting a new alt. Im not sure if this momentary time while trying to start or shortly after with the alt not working right may have causes this? anyone have this happen before?
Zaridar is offline
post #2 of 5 Old 11-17-2011, 02:03 PM
I have actually had this exact thing happen before on my 09, not sure what the deal was. But I jumped it let it charge cleared the CEL and never saw it again.
cwinterbower is offline
post #3 of 5 Old 11-17-2011, 02:17 PM
I have seen the TGV motors take a dump over time. Check those.
post #4 of 5 Old 11-17-2011, 05:09 PM
wagonracer's Avatar
Deal with the alternator (which it looks like you are doing) first. A charging issue can cause all sorts of erroneous CELs. Don't start chasing any other possible issues until your voltage is solid.
Cullen
wagonracer is offline
post #5 of 5 Old 11-17-2011, 10:26 PM Thread Starter
This was my plan.. I hope it was as you say just erroneous CEL. Thanks
Zaridar is offline
