Tranny Reverse whine and grind - Page 2 - Subaru WRX Forum
post #16 of 33 Old 05-24-2009, 11:13 AM Thread Starter
isd_intrepid's Avatar
isd_intrepid is an unknown
Send a message via Yahoo to isd_intrepid
i wasn't arguing it. i was just researching it. so i sounded less like a gooney.
Also i can't remember which model was the "better" transmission. the AA or the AB
check out my car domain here. Mod list and Pix
isd_intrepid is offline
post #17 of 33 Old 05-24-2009, 11:27 AM Thread Starter
NP dude. i've only had 3 hours sleep myself. and now i'm sitting at work for 12 hours. WOOT
post #18 of 33 Old 05-24-2009, 11:32 AM
Originally Posted by C89ZX7R View Post
The throw out bearing stays on the transmission when the tranny is removed.
I thought it attached to the pressure plate which dose not come out with the transmission. once the throw out bearing clips into the pressure plate its pretty damn hard to get it off. that is why you have to pull the release lever out before you seperate the transmission from the engine.
nagyhead is offline
post #19 of 33 Old 05-24-2009, 11:51 AM Thread Starter
Originally Posted by basco View Post
did they show you the heat spots...or were they just like you have heat spots come give us money?
sorry dude missed ## post. i did see the heat spots on the plate. and on the clutch disc. the center area was purple. and the contact surface area had less than a millimeter left.
post #20 of 33 Old 05-24-2009, 12:57 PM Thread Starter
I'm not sure if the fly wheel needs to be replaced or not. i haven't seen it. but it already has been resurfaced once.
post #21 of 33 Old 05-24-2009, 01:18 PM
you can only resurface our flywheels once so it would be in your best interest to replace it
post #22 of 33 Old 05-24-2009, 01:45 PM Thread Starter
that's what i was thinking. but since i have to order the parts through the dealership, so i can charge it to my account, would it be better to put the SPT flywheel. or should i just put on the OEM?
I know the old addive. stock tranny = stock clutch. just asking if it would be better.
post #23 of 33 Old 05-24-2009, 02:03 PM Thread Starter
cash at this moment is something i don't have. so that's why i have to charge it to the account. sucks cause i have 2 payments coming at the begining of the month and could buy the parts then. but they won't let me use the new "loaner" that long. so i'm kinda forced into getting the parts from then only because of time.
post #24 of 33 Old 05-24-2009, 02:13 PM Thread Starter
no. i just have a charge account with the dealership.
post #25 of 33 Old 05-24-2009, 02:25 PM Thread Starter
yeah. well i guess if i'm gonna get shafted in this deal i might as well get some good parts right?
so would the SPT clutch and flywheel cause me problems down the road?
post #26 of 33 Old 05-24-2009, 03:03 PM Thread Starter
i'll probably go with the organic clutch 8mm. and just get the oem flywheel.
I'm not sure if they ordered it or not. It was 4:45 on Friday. with memorial day weekend comming up. i was surprised to see any techs still in the shop.
post #27 of 33 Old 05-24-2009, 03:26 PM Thread Starter
well i guess i can get personal satisfaction and pay them off $50 a month. since there is no interest.
post #28 of 33 Old 05-24-2009, 04:59 PM
boo-key's Avatar
Try to get that PITA teenage girl to help you pay.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #29 of 33 Old 05-24-2009, 05:32 PM Thread Starter
yeah. not happening. already been down that road. she refuses to even admit she did anything wrong.
post #30 of 33 Old 05-31-2009, 08:43 AM Thread Starter
FINAL UPDATE:
I now have the car back and have been breaking in/ learning to use this new 8mm Organic Clutch since Thursday of last week. I'm pretty happy that this nightmare is over. The only small problem that i haven't decided to tackle yet is: The Stealership broke one of my neon tubes under the car. and now the system is useless. I really don't know if its going to be worth the time to get them to replace the tube. in the 3 years i've own the car, 3 tubes have been broken, and none of them have been the result of me breaking them. I think i'm going to put on a mutli color LED system ($300 installed) vs getting the replacement tube installed ($140)
Anyway. thanks for the 2cents of all the peeps that threw in on this. And make sure you tell the story, its not going to hurt my ego any.
