tranniez - Subaru WRX Forum
post #1 of 14 Old 01-11-2003, 11:51 PM Thread Starter
WRX TYPE-R is an unknown
tranniez
does the WRX really have a glass tranny??
WRX TYPE-R is offline
post #2 of 14 Old 01-12-2003, 12:41 PM
mikeWRX's Avatar
mikeWRX is an unknown
No it doesn't. Unless you are making a lot more than 300 ft lbs of torque and do a lot of clutch drops and power shifting.
mikeWRX is offline
post #3 of 14 Old 01-12-2003, 12:46 PM Thread Starter
well that pretty much takes the fun out of an AWD car!
post #4 of 14 Old 01-12-2003, 12:57 PM
mikeWRX's Avatar
Well, It's mainly 1st and 2nd gears you have to be careful with.
mikeWRX is offline
post #5 of 14 Old 01-12-2003, 01:22 PM Thread Starter
so im guessin a stronger clutch n lighter flywheel would help out?? wut else would help??
post #6 of 14 Old 01-12-2003, 01:28 PM
mikeWRX's Avatar
Actually a stronger clutch can make the situation worse. It will transmit more of the shock to the tranny than if the clutch slipped a little. Stronger 1st and 2nd gears helps the most but a lot of people are pushing a lot more than 350HP without any tranny damage. They are just being careful. Some people have bought aftermarket dog ear gears but that is fairly expensive. Others have done STi tranny swaps.
mikeWRX is offline
post #7 of 14 Old 01-12-2003, 05:52 PM Thread Starter
whats an aftermarket dog ear gear?? and how much do the dog ear gears and the STi tranny cost??
post #8 of 14 Old 01-12-2003, 11:23 PM
latinWRX's Avatar
latinWRX is an unknown
Sorry,but what's a tranny? and why does WRX- type R ask if it's glass? is that likea metaphoric name or something?
"Many people have a good aim in life; most never pull the trigger."
latinWRX is offline
post #9 of 14 Old 01-13-2003, 04:21 PM
mikeWRX's Avatar
Dog ear gears are straight cut not helical (they don't have synchro's, so you have to rev match).
A Tranny is a transmission.
When you say it is glass it means it breaks easily.
mikeWRX is offline
post #10 of 14 Old 01-30-2003, 12:10 PM
DJSpaghetto69 is an unknown
Send a message via AIM to DJSpaghetto69
Mike, I have been looking high and low for a JDM STI gear box, any subjestions?
JDMness... Yum!
DJSpaghetto69 is offline
post #11 of 14 Old 01-30-2003, 10:15 PM
mikeWRX's Avatar
go here
http://www.noztune.com.au/specials.htm
This place sells them
mikeWRX is offline
post #12 of 14 Old 02-02-2003, 05:45 PM
imprezzor is an unknown
I blew my tranny with 45 000 miles on an o2 rex
imprezzor is offline
post #13 of 14 Old 02-16-2003, 03:49 PM
SubaruTech is an unknown
if you are hard on the car then yes, stock wrx transmissions are "glass" if you drive more conservative than others, sure it will last longer. same with awd dsm.
it all depends on how its driven, theres no right or wrong answer but this is the closest you will get to one.
if u are pushing more than 300 hp and expeirience clutch slip, i would try a stronger clutch plate with a new "stock" disk... increasing clamping force but under too much torque, she'll slip a bit
I have a DSM. Im a Subaru Technician. I like to check out the site to help a bit with diagnosis and to learn about the "WRX perfrormance" end of the stick.
SubaruTech is offline
post #14 of 14 Old 02-24-2003, 09:14 AM
What ever you do, do not got with a unsprung hub assemble (Unorthidox Racing). This is the best way to destroy a tranny.
JDMness... Yum!
