tail lights won't turn off - Subaru WRX Forum
 4Likes
  • 2 Post By Epictofer
  • 2 Post By Brockton
post #1 of 8 Old 07-10-2014, 01:29 PM Thread Starter
kirby32rex is an unknown
Does anyone know why my tail lights won't go off? I have disconnected the battery and turned back on and still they stay on. They constantly stay on when key is out of ignition if battery is connected.
kirby32rex is offline
post #2 of 8 Old 07-10-2014, 01:43 PM
arcticscythe's Avatar
This is gonna sound kind lame but did you turn the lamps off with the turn signal indicator column? Thats the first thing I would check, try rolling the light on and off with the column, you may have a faulty relay that's stuck in the open position or even a faulty brake lamp switch.
The universal procedure would be to check the DRL controls first and if that's not it get under your dash and look for the brake lamp switch, its usually attached to a bracket and your brake pedal assembly makes contact with the switch near the pedal hanging hardware. Sometimes the brackets are bent out of whack or the switch fails. You can always check it by disconnecting the switch at the pedal and see if the lamps go out.
To give you more information we need to know the your and model or your vehicle. then we can give you more specific instruction.
- Jason
arcticscythe is offline
post #3 of 8 Old 07-10-2014, 02:00 PM Thread Starter
Yeah I have checked all the lights to make sure they are off. I have read up a bit on the switches under the brake pedal and how it works but that pin that the brake releases pressure off of for the lights is for the brake lights not the tail lights right? So that still have to do anything with it? Oh sorry btw it's an 2005 subaru wrx impreza
post #4 of 8 Old 07-10-2014, 02:28 PM
Epictofer's Avatar
Epictofer is known to be trustworthy and helpful Epictofer is known to be trustworthy and helpful Epictofer is known to be trustworthy and helpful
very possible your brake light switch is bad, but on the older models there is a parking liguht switch on top of the steering comlumn that when depressed leaves the parking lights on all the time. it gets pressed while cleaning most times. seen it about 50 times here at the dealership
BLAZE2099 and Brockton like this.
Epictofer is offline
post #5 of 8 Old 07-10-2014, 03:44 PM Thread Starter
Epictofer Ty very much I have never noticed that switch haha. That was my issue thank you, I feel stupid now after trying to figure that out forever.
post #6 of 8 Old 07-10-2014, 05:13 PM
Brockton's Avatar
Beat me to it, it happens alot on the older years.
BLAZE2099 and Epictofer like this.
Brockton is offline
post #7 of 8 Old 07-18-2014, 06:53 AM
Epictofer's Avatar
Cool glad thats all it was!! I had a customer come in the other day that had this problem! happens all the time
post #8 of 8 Old 07-21-2014, 02:55 PM
This needs pinned. I see it on here at least a half dozen times a year.
