sub fan not coming on - Subaru WRX Forum
post #1 of 1 Old 06-20-2013, 11:30 AM Thread Starter
my sub fan never comes on. even with the a/c. oddly, neither fan comes on with the a/c immediately - i thought they were supposed too. both speed relays are good, the fuse is good, and the fan works if i give it power directly. interestingly, the sub fan relay 1 does not have power available at its connector to power the fan (the switch part). the second relay does. this first relay has its power wire, a green/yellow, going back in the loom somewhere. I've seen a wiring diagram that shows both relays getting their power from the same fuse inside the relay box, but mine is not like that. any ideas?
fawcetteng is offline
