-   -   Stumped overheating 02 WRX (http://www.wrxtuners.com/forums/f72/stumped-overheating-02-wrx-39977/)
JCMON 10-03-2013 12:15 PM
Anyone please help, totally stumped!
Replaced radiator with new Mishimoto alum and new themostat. Have overheating problems and no heat. radiator is pushing fluid back out when increasing rmp's. top hose hot while bottom is still cool.
Already checked the new thermostat, boiling water method (good)
Already burped the system multiple times, also drained radiator and refilled through overflow (to make sure) also ran heater when filling
Already tested head gasket (good)
looking for any answers aside from replacing the water pump? really don't want to do this if unnecessary.
Any help would be very much appreciated :(
Nathan21 10-03-2013 12:23 PM
Just my 2c but did you check if your fans are kicking on, I am not good with these cars yet still a newb, but I know the guys on here wil chime in and correct me
JCMON 10-03-2013 12:35 PM
Yes, both fans come on and seem to be working fine. thanks.
06_hawk_eye 10-03-2013 01:21 PM
No heat would leave me to believe that there is air in the system. When I replaced my rad in mine with a misho aluminum one like yours I had to let it run for 30 mins almost and every once and awhile I'd hold the rpms at 2000. These systems can really be a b1tch to bleed
JCMON 10-03-2013 02:05 PM
Thanks for the info: I'll give it another go around. I'm not sure what else I can do aside from fill from the overflow and squeeze the hoses. I stood with a funnel on top of the radiator yesterday watching it puke back and forth without ever looking like the level was going down. I massaged the hoses, ran the heater, jumped up and down and still nothing changed.
One more time I guess.
Any idea how I could eliminate the possibility of a bad water pump aside from removing it?
06_hawk_eye 10-03-2013 04:14 PM
Is there 2 reservoirs. On your model?
JCMON 10-03-2013 05:01 PM
not that I'm aware of? just the radiator and the overflow near the turbo.
boo-key 10-03-2013 05:07 PM
549 Attachment(s)
The one next to the turbo is the one you fill. Always fill from the highest point in the system which is this one. No need to even open the cap on the radiator. Fyi the plastic jug next to the radiator is the overflow not the reservoir next to the turbo.
06_hawk_eye 10-03-2013 06:12 PM
Fill from the one next to the turbo and all problem should be solved. You have a shit ton of air in the system I'm guessing
