-   -   Strange Smoke/Smell (http://www.wrxtuners.com/forums/f72/strange-smoke-smell-47506/)
justin93m 04-10-2014 08:56 AM
Strange Smoke/Smell
well i had this strange smoke and smell coming from my turbo area. literally checked all over the motor and turbo found nothig. then i checked under the car and noticed the axle boot was torn and there was axle grease everywhere under my downpipe! i guess the question i have is how bad can this get ? i got two weeks to go till i get paid and need to know if it can make it till then
AllExtinct 04-10-2014 10:49 AM
Really depends on how much you plan to drive it,how long of trips and what kind of terrain.
If the boot just tore you have a small amount of time before all the grease comes out.
Driving on dirt terrain will cake up the amount of grease left and make it worse faster.
Im sure you can wing it till you get paid just try not to drive any more than you have to for now.
arcticscythe 04-10-2014 12:21 PM
Justin39,
Swapping out a axel boot is usually a pretty painless process, Provided you have the tools for the job. Replacement boots can be had as cheap as $20-$30 and assuming your only doing the one its a 3-4 hour job. If its a fresh tear you can drive on it a bit without too much worry but if dirt gets in the CV joint it will cause irreversible damage very fast. If all the grease has been ejected from the torn boot or you can feel grit in the boot then its time to replace the whole Joint or in most cases just swap the axel.
If it turns out to be an axel swap it can cost you a bit more than a hundred dollars. you can get new axels online for about $125 shipped, the install process is easier than replacing the boots by themselves and doesn't require those damn C-clips.
TLDR - If the damage is fresh and the CV joint is still clean you should be OK to drive until payday, if you have time and $20 before then you can swap out a boot in an afternoon.
LW_Black4 04-10-2014 05:08 PM
[B]Awesome information Jason[/B], and thank you for being so helpful providing it.
You are representing wrxtuners.com superbly! :)
arcticscythe 04-10-2014 07:16 PM
Im always glad to help, something about karma : )
