Stock Wastegate causing boost issues??? - Subaru WRX Forum
post #1 of 4 Old 11-01-2009, 10:33 PM Thread Starter
jo1234la is an unknown
I have an 04 STi I bought used. It has a downpipe, catback, intake and HKS SSQV. The car was running about about 17 Psi Boost at max boost give or take a pound or 2 for spikes.
Recently the car started acting up. The boost started to intermittently revert back to 10 PSi Max. Now the boost is permanently at max 10 Psi with a bit of a spike to 12Psi at max RPM.
1. Is 10 Psi the stock waste gate setting for an 04 STi?
2. Does anyone know if this is a stock boost stabilizer issue?
3. Has anyone else had the same problem?
I would appreciate any advice............... Thanks!Laugh!
jo1234la is offline
post #2 of 4 Old 11-01-2009, 11:28 PM
midniteblack's Avatar
midniteblack is more helpful than not
Send a message via AIM to midniteblack
You may have a boost leak or your wastegate is broken/loose causing your low boost issue.
midniteblack is offline
post #3 of 4 Old 11-02-2009, 12:06 PM
+1 to the above mentioned. Check for leaks, and then check the wastegate arm. Make sure the C-clip didnt fall out either.
post #4 of 4 Old 11-02-2009, 08:51 PM
10 psi sounds like wastegate pressure on a VF39. Either the BCS is acting up or The ECU has dropped IAM and is running with reduced timing. Without a datalog it will be hard to tell.
dumdum is offline
