Stock Hood Scoop w/ Aftermarket Intercooler - Subaru WRX Forum
post #1 of 11 Old 09-12-2008, 12:53 PM Thread Starter
Sorry guys I've researched as much as I could before starting a thread. I have an 06 wrx w/ an ebay aftermarket intercooler. The stock hood scoop has a rubber lining underneath it I guess to keep it air tight at stock. The problem is that now with the intercooler is that rubber lining of the hood scoop is rubbing and mainly squeaking against the intercooler. It also is constricting the air flow to only reach about 60% of the intercooler because the lining cuts off the rest. Is it safe to cut this lining off now? There is also like a exhaust capsule to the left on the hood scoop about 4 inches wide. Is it safe to gut everything off the hood scoop to allow max air flow and stop this squeaking sound?
robelia1 is offline
post #2 of 11 Old 09-12-2008, 06:31 PM Thread Starter
Nobody?
robelia1 is offline
post #3 of 11 Old 09-12-2008, 11:55 PM
get rid of it , its fine.
nagyhead is offline
post #4 of 11 Old 09-14-2008, 03:26 PM Thread Starter
So there is no danger in removing that lining in terms of water and other things getting into other parts of the engine?
robelia1 is offline
post #5 of 11 Old 09-14-2008, 06:45 PM
nope.
nagyhead is offline
post #6 of 11 Old 09-15-2008, 09:34 AM
The sqeak you are hearing isn't from the rubber piece, it's from 3 plastic clips that hold the windshield wiper hose. Just remove the rubber piece under the hoodscoop (its ok to do this) and remove the plastic clips, cut the hose a little to give it a tighter fit so it doesnt hang and your good to go.
sfelix818 is offline
post #7 of 11 Old 09-15-2008, 10:55 AM
They also make aftermarket airsplitters for larger TMIC.The rubber skirt is not for sheilding water,its to seal the top part of the TMIC from the engine bay and for the air to get forced through the intercooler.
dumdum is offline
post #8 of 11 Old 09-15-2008, 12:36 PM Thread Starter
All of this sounds good I will have to look under the hood later. What about that portion of the hood scoop on the left side where it looks like its almost a vent. Its about 4 inches long and it doesn't look like air is able to get to the intercooler.
robelia1 is offline
post #9 of 11 Old 09-15-2008, 05:48 PM
It lets the heat from the turbo/underhood vent out durring stationary idling
dumdum is offline
post #10 of 11 Old 09-15-2008, 05:49 PM
That part diverts some air down toward your turbo to cool it
post #11 of 11 Old 09-15-2008, 06:53 PM Thread Starter
Hah ohhhh, so i'm guessing I should leave that be...
robelia1 is offline
