ok had a greddy profec b got rid of it cause it was hittin high boost anymore thought it was broke... went back to factory setup still didnt boost over 10lbs...i unplugged the wastegate hose to se if it would go higher it worked then plugged it back in and now guage reads 1lb unplugged the waastgate hose again and only hit 10lbs.... wtf is wrong
damn i forgot the restirctor pill threw that line out with it still in didnt think i was gonna go back to stock....
and i solved one problem the overboost blew off a vaccum hose already fixed reads boost back to 10 but i want the factory 14
Since you are missing your factory resticto pill, look into a 3 port BCS and get a tune done right after install, will solve the low boost and even get you a little more and safer.
