Steering wheel shake like crazy! - Subaru WRX Forum
post #1 of 13 Old 06-01-2012, 03:46 PM Thread Starter
nicholas3000 is an unknown
Hi guys, I don't know if you can help me...
When I'm driving on the highway, I always have a shaky steering wheel, even after I got my 4 wheels balanced... When I touch the brakes, the steering wheel just start to go crazy.
I tought it was the disk that was warped, but after replacing the four disks and all the brake pads, it's still shaking and seems to get worse.
My dealer doesn't have any appointement available until next week, and I don't want to lose a wheel while driving until then!
It's a 2008 WRX if it can help.
Thanks
nicholas3000 is offline
post #2 of 13 Old 06-01-2012, 04:04 PM
bad grocerygetter's Avatar
Are the tires new? I would go back to where you got it balanced and see what they say. If they aren't new you probably have a bad tire(or two). Sucky part is you don't wanna replace just one or two, you need to have the same tread height on all four. If you dont you can really mess up your car. Now if you just bought them I would be going right back to the place you got them for the problem to be fixed.
Kevin.
Last edited by bad grocerygetter; 06-01-2012 at 04:10 PM. Reason: additional thoughts
bad grocerygetter is offline
post #3 of 13 Old 06-01-2012, 04:14 PM
1. Your tire is out of round.
2. Your wheel is bent.
3. Your have tie rod play.
post #4 of 13 Old 06-01-2012, 04:48 PM
Any squeaking or squealing or chirping from any corners?
post #5 of 13 Old 06-01-2012, 05:09 PM
Switch the front to the back and see if it subsides... Or goes away... either one... if it does then it's a tire or wheel. If not, what brfatal said.
Easiest way to find out if you are at home and can do this yourself in 20 mins.
post #6 of 13 Old 06-02-2012, 06:42 PM Thread Starter
I got the tires last year, there's only 4000 miles on them... I doubt it would be the tires or the wheels, because it's doing the same thing with my winter tire and wheels.
post #7 of 13 Old 06-02-2012, 06:45 PM Thread Starter
What's the best way to check for tie rod play? Also, someone told me it might be a wheel hub, would it be possible? My steering wheel is also shaking a little bit when i'm driving at 60mph.
post #8 of 13 Old 06-02-2012, 06:52 PM
Did they tighten down the lugs? Hate to ask that question...but its happened to people I know.
post #9 of 13 Old 06-02-2012, 07:09 PM
Jack it up, grab the top of the wheel and the bottom of it at once. See if you can wiggle it in and out.
Whether it does or not, than pull the wheel off and try to wiggle all the bits in there. Nothing should wiggle too much. A very little play is normal ( like a 32nd of an inch at most )
post #10 of 13 Old 06-02-2012, 07:10 PM
05wrxcm is an unknown
What about your alignment? A friend of mine would hit curbs (on accident) and his toe was off by 1.2 degrees if I remember correct. But him having 1 tire with a messed up toe angle made the steering wheel shake horribly.
05wrxcm is offline
post #11 of 13 Old 06-02-2012, 10:52 PM Thread Starter
Alright, I will check for the free play tomorrow.
I got the aligment done on march, I had 1 degree off on the rear left wheel, but it didn't fix anything.
post #12 of 13 Old 06-02-2012, 10:53 PM Thread Starter
Yep, the lugs are all tight!
post #13 of 13 Old 06-03-2012, 10:11 AM
Jack the front up and try to feel for hub play like Randy suggested. You might even be able to feel for it when it's on the ground if it's that bad.
