starting problem - Subaru WRX Forum
post #1 of 8 Old 06-26-2004, 01:52 AM Thread Starter
WRX_Stud is an unknown
starting problem
ok .. so ive searched and searched and found nothing on this problem .. so my problem is this : when i go to start the car, all i hear is a click, everything i turn the key .. and i know i have full power because everything works fine and i have no problem with is when i "jump start " the car .. so anyone have any idea on what this may be ??
WRX_Stud is offline
post #2 of 8 Old 06-26-2004, 07:19 AM
WRXtreme's Avatar
You may have enough power to run some accessories, but once you go below 12v or so, its not enough to start the car. The first thing I would say to do is get a multi-meter and check the battery OR if your car is still under warranty, call the dealership and have them fix it for free.
WRXtreme is offline
post #3 of 8 Old 06-26-2004, 08:28 AM
BlueDemon's Avatar
BlueDemon is known to be trustworthy and helpful BlueDemon is known to be trustworthy and helpful
You're hearing a click when you try and start the car? Your battery is dead, or dying. I've had mine do the same thing, and it started on its own for about a week, until it finally went. Subaru actually replaced the battery under warranty for me. Be sure replace the battery soon, as you can put a strain on your Alternator and possibly fry it.
Blue
BlueDemon is offline
post #4 of 8 Old 06-26-2004, 01:26 PM Thread Starter
well actually .. my volt meter on my battery has 13 .... i had to do a custom install for my car stereo which included custom wiring system and battery ... so i had ruled out the battery and alternator
WRX_Stud is offline
post #5 of 8 Old 06-26-2004, 03:29 PM
BlueDemon's Avatar
Well, if you're sure it's not your battery and alternator, then it's your starter going.... that's the only thing I can think of.
Blue
If it's a humming or a buzzing you're hearing, it's your fuel pump.
post #6 of 8 Old 06-27-2004, 09:47 PM
Kobiyashi's Avatar
Kobiyashi is more helpful than not
Re: starting problem
Your answers on your last few responces contradict yourself, because if a jump start works, it can ONLY be the battery, everything else is still needed to start the car. Check for a loose wire on the post or swap it with the battery you were jumping it with just to try that. It's either the battery or the connection to the battery.
-kobi
Kobiyashi is offline
post #7 of 8 Old 06-27-2004, 10:15 PM
T WREX's Avatar
T WREX is an unknown
Send a message via AIM to T WREX Send a message via Yahoo to T WREX
Maybe he means rolling the car in gear and dumping the clutch when he says "jump start". If so, he's not contradicting anything.
FP Green'd 04 STi
Trevor
T WREX is offline
post #8 of 8 Old 07-01-2004, 07:37 PM
Kobiyashi's Avatar
even then its still only the battery (or possibly starter if you use a clutch jump) if it RAN without any change. Everything else is needed to run. So Jump from a battery or clutch pop either way its easy to troubleshoot.
-kobi
