start up and dies instantly - Subaru WRX Forum
post #1 of 16 Old 01-13-2010, 04:26 PM Thread Starter
slvr04wrx is an unknown
my car will stall out instantly after start up but only on a warm engine. cold start it will crank up to the high rpm's and continue to run. but only with a warm engine will it die. i just had the o2 sensor replaced which fixed the main issues i had with it all except for the start up stall. does anyone have any ideas or does anyone else have this problem? i just have no idea what would be causing this.
slvr04wrx is offline
post #2 of 16 Old 01-13-2010, 04:46 PM
WRXforME's Avatar
WRXforME is an unknown
Upside down MAF? That can cause that, I believe. If the MAF on the intake isnt installed back exactly the way it was, it screws with it.
WRXforME is offline
post #3 of 16 Old 01-13-2010, 05:21 PM
VD5505's Avatar
Have you checked for any vacuum leaks?
2003 WRX Hybrid build,
Brian
VD5505 is offline
post #4 of 16 Old 01-13-2010, 05:24 PM Thread Starter
yeah when my car first started messing up i cleaned the maf so i know its clean and it went back in the way it came out, havent checked the vacuum leaks yet
post #5 of 16 Old 01-13-2010, 08:08 PM
VD5505's Avatar
Do you have a way to test your fuel pressure?
Brian
VD5505 is offline
post #6 of 16 Old 01-14-2010, 09:06 AM
you could also try cleaning your Idle Air Control Valve
Cleaning And Reattaching The IACV (Idle Air Control Valve) - NASIOC
post #7 of 16 Old 01-14-2010, 03:25 PM Thread Starter
no i dont have a way to test my fuel pressure. but it will start and run on a cold start. but it will rev up and die on a warm start though.
post #8 of 16 Old 01-14-2010, 07:13 PM
Did you use MAF cleaner ? Did you happen to touch the MAF sensor ?
post #9 of 16 Old 01-14-2010, 09:33 PM Thread Starter
no i didnt touch it i used some maf spray cleaner
post #10 of 16 Old 01-15-2010, 05:40 AM
Did you do the IACV like the previous poster said to do??
post #11 of 16 Old 01-15-2010, 11:41 AM
yeah and if your car has a check engine light on please get it read and post the code here and your full mod list as that would make this hella easier to diagnose but i can think of at least 15 things that could cause this it would be helpful to have more info before I start leading you down the wrong path
post #12 of 16 Old 08-31-2010, 06:46 PM
phatmike0704's Avatar
phatmike0704 is an unknown
Send a message via AIM to phatmike0704 Send a message via Yahoo to phatmike0704
so ### was the problem
phatmike0704 is offline
post #13 of 16 Old 08-31-2010, 06:55 PM
He probably won't be back to answer, I wish people would remember to do that more. It helps other diagnose things easily when they come back and tell you what it was...
post #14 of 16 Old 11-04-2010, 01:23 PM
baumgartenb's Avatar
baumgartenb is an unknown
I'm having a similar problem with my 02 wrex. I installed a coi and when I put it together the car woud start then die...i tried turning the sensor the other way, still there.the only way my car will run with the maf sensor pluged in is if I take the filter off and put my hand in ront of the hole.. If I take the maf sensor of the car will un but cut off at certain points when I accelerate. Please help I am entering it in a rally in two days.
baumgartenb is offline
post #15 of 16 Old 11-04-2010, 02:22 PM
Run a stock intake...or get a tune
