stage 2 question - Subaru WRX Forum
post #1 of 6 Old 05-14-2007, 05:34 PM Thread Starter
07wrx_red is an unknown
Send a message via AIM to 07wrx_red
stage 2 question
ok how do you tell if you flashed stage 2 i pretty sure i did but i am getting a cei and a flashing cruise light when i am on it hard in 4th and 5th the light turns off after i take the keyout and restart the car i think it is boost creep which you guys say happens when you get a dp and no em any suggestions.
07wrx_red is offline
post #2 of 6 Old 05-14-2007, 05:42 PM
wrxgtr's Avatar
wrxgtr is more helpful than not
Send a message via Yahoo to wrxgtr
you need to read your ecu with ecuflash save it then use enginuity to compare it to the stage 2 map and see if they are the same
MIKE
TUNED BY 555 MOTORSPORTS
visit me @ www.myspace.com/subienews
wrxgtr is offline
post #3 of 6 Old 05-14-2007, 05:58 PM Thread Starter
i tried to open it in enginuity and it says ecu def. not found
post #4 of 6 Old 05-14-2007, 08:05 PM
wrxgtr's Avatar
here are the 07 defs unzip them then drag and drop them into the enginiuty file
MIKE
wrxgtr is offline
post #5 of 6 Old 05-14-2007, 08:40 PM Thread Starter
ok i reflashed stage 2 and i think it is now working i logged it. and everything when fine i think what is boost is it manifold relative pressure. (noob question how do i put a log in here as a link)
post #6 of 6 Old 05-14-2007, 08:53 PM
wrxgtr's Avatar
you should actually post it on www.osecuroms.org so the devloper can see it
im glad it all worked out for you
MIKE
wrxgtr is offline
