Sound on startup - Subaru WRX Forum
 3Likes
  • 1 Post By brfatal
  • 2 Post By cpeeler21
post #1 of 11 Old 01-21-2014, 02:47 PM Thread Starter
cpeeler21 is an unknown
Unhappy Sound on startup
Car runs perfect. Sound goes away after long warmup. I thought there was a rattle noise near the radiator also. All started after negative weather. Always warmed car up before running and drive car 5 miles to work. Never run hard. New timing belt 5k miles ago and smooth idle.
cpeeler21 is offline
post #2 of 11 Old 01-21-2014, 03:48 PM Thread Starter
Youtube Video of the noise
2005 WRX Noise - YouTube
post #3 of 11 Old 01-21-2014, 04:59 PM Thread Starter
Note* Sound not really going away after warmup.
post #4 of 11 Old 01-21-2014, 05:28 PM
Your belts need to be readjusted or replaced.
the RIOT act likes this.
post #5 of 11 Old 01-21-2014, 07:44 PM Thread Starter
Crazy…I just had them all replaced with timing belt no more then 5k miles ago….
post #6 of 11 Old 01-21-2014, 07:58 PM
Premium Member
the RIOT act's Avatar
Sound on startup
I'd def have to agree with brfatal after listening.
Most shops are slackers man. Nothing new lol! I'd take it back to them and have them hear it. There should be no charge to make the needed adjustments.
Sent from AutoGuide.com App
Brandon - 13' SWP WRX Sedan
the RIOT act is offline
post #7 of 11 Old 01-21-2014, 11:20 PM Thread Starter
Hey, Thanks for the advice. I'll bring it to the shop and have them take a look at the belts.
post #8 of 11 Old 01-22-2014, 12:11 AM
Brockton's Avatar
The acc belts loosen when they are new, I had to tighten them a few times over the couple weeks after I installed them.
Brockton is offline
post #9 of 11 Old 01-22-2014, 06:05 PM Thread Starter
Brockton, Is the tightening process difficult? Something I can do myself. I have a good grasp on simple repairs. I have done the spark plugs, turbo heat shield, all new turbo related hoses...
post #10 of 11 Old 01-24-2014, 12:05 AM Thread Starter
Loosened the belt a little bit and the sound went away. The stealership put the belt on hulk style.
turmic and the RIOT act like this.
post #11 of 11 Old 04-21-2014, 07:58 PM
sdunlimited is an unknown
I know this thread is a few months old, but if that sound comes back I found it to be the idler pulley on the accessory belt. When the bearing in my cheap plastic OEM went I thought the car was on it's last leg! It screeches and whines something horrendous. The aftermarket replacement is a metal version with a better quality bearing and sounds whisper quiet compared to the burnt out one being replaced.
sdunlimited is offline
