Some of my fan speeds (for AC) stopped working - Subaru WRX Forum
post #1 of 5 Old 09-22-2010, 08:37 PM Thread Starter
Nose Nuggets's Avatar
Just to be clear off the bat, i am talking about the AC fans in the cabin on my 03.
About 6 months ago the #2 fan speed stopped working entirely. 1, 3, and 4 all worked normally, but if you put it on #2 the fans stop entirely. Today when i got in the car 1, 2, and 3 all don't work, only 4 (full blast) works. A/C still seems to function normally, and toggling the A/C on or off does not effect the issue. The dial itself works normally, it does not feel different when moving it across the different settings.
Any ideas on where to start for diagnostics? or has someone else had the problem and know what it is?
Thanks in advance for any suggestions,
Tristan
Nose Nuggets is offline
post #2 of 5 Old 09-22-2010, 09:07 PM
sounds like your HVAC controls are dying, had that happen in the Supra
post #3 of 5 Old 09-22-2010, 09:43 PM Thread Starter
ooohhh. you think the control cluster just needs to be replaced?
post #4 of 5 Old 09-22-2010, 10:13 PM
yeah, try just swapping with a pal first
post #5 of 5 Old 10-21-2010, 01:26 PM
I believe there is a resistor pack for the switch that is gone. Each speed has a resistor (other than the high speed). Something like that.
Did you figure it out?
Dave.
kawika is offline
