Smoke from front right engine - Subaru WRX Forum
post #1 of 6 Old 09-17-2012, 10:49 AM Thread Starter
Kurt_Sweethat is an unknown
I own a 04 wrx, stock motor with 130k on it, and when my engine heats up to normal operating temperature it starts to smoke when I come to a stop. I if I sit long enough, the smoke will come out of my scoop and front right hood area. Now, I do have a split in my right cv boot and there is grease that has been flung out from it, I think it's from that. I have a new one on the way. My question is, could it be from somewhere else? Cause I can't pinpoint the exact cause of the smoke and burning smell. I just want to make sure I'm not missing anything.. Anyone else have a similar problem? Thanks!
Kurt_Sweethat is offline
post #2 of 6 Old 09-17-2012, 01:22 PM
The grease from the boot can smell bad. It's probably the issue. Fix it and clean everything real well and see if it persists.
post #3 of 6 Old 09-17-2012, 04:11 PM
AllExtinct's Avatar
An easy way to check to see if its the grease is after your done driving park and let the engine idle for a few minutes and see if the smoke stops.
Good luck.
Cobb Accessport Stage 2.
JDM ej205 swap.
Home state: PA Crew
Chuck.
AllExtinct is offline
post #4 of 6 Old 09-17-2012, 08:13 PM
sleepr's Avatar
Images: 13
sounds similar to the symptoms that preceded the replacement of my turbo...
Matt
Stroked and stoked!
sleepr is offline
post #5 of 6 Old 09-18-2012, 05:24 AM Thread Starter
Thanks. Hopefully the cv boot will fix it.
Sent from my ADR6400L using AutoGuide.Com Free App
post #6 of 6 Old 12-02-2012, 06:51 PM
derek86ux is an unknown
i have this exact same problem. have you figured out what it was yet? please let me know.
derek86ux is offline
