-   -   Smoke from front right engine (http://www.wrxtuners.com/forums/f72/smoke-front-right-engine-33023/)
Kurt_Sweethat 09-17-2012 11:49 AM
I own a 04 wrx, stock motor with 130k on it, and when my engine heats up to normal operating temperature it starts to smoke when I come to a stop. I if I sit long enough, the smoke will come out of my scoop and front right hood area. Now, I do have a split in my right cv boot and there is grease that has been flung out from it, I think it's from that. I have a new one on the way. My question is, could it be from somewhere else? Cause I can't pinpoint the exact cause of the smoke and burning smell. I just want to make sure I'm not missing anything.. Anyone else have a similar problem? Thanks!
pzr2874 09-17-2012 02:22 PM
The grease from the boot can smell bad. It's probably the issue. Fix it and clean everything real well and see if it persists.
AllExtinct 09-17-2012 05:11 PM
An easy way to check to see if its the grease is after your done driving park and let the engine idle for a few minutes and see if the smoke stops.
Good luck.
sleepr 09-17-2012 09:13 PM
sounds similar to the symptoms that preceded the replacement of my turbo...
Kurt_Sweethat 09-18-2012 06:24 AM
Thanks. Hopefully the cv boot will fix it.
Sent from my ADR6400L using AutoGuide.Com Free App
derek86ux 12-02-2012 07:51 PM
i have this exact same problem. have you figured out what it was yet? please let me know.
