*sigh* Redlined. Bov and turbo not working - Subaru WRX Forum
 9Likes
post #1 of 46 Old 09-30-2013, 10:58 AM Thread Starter
mpinto19k's Avatar
mpinto19k is an unknown
So this morning I was trying to merge onto a shity Texas highway, get on the on ramp and gun it, newbie mistake, was so focused on my mirrors trying to make sure I wasn't about to get smashed by another car that I redlined the shit out my 2005 WRX. Now it sounds like straight garbage and my BOV and Turbo are not working. It seems like the turbo is trying to spool but appears there's a leak some where? I looked under the hood and everything seems to be ok and intact. I'm extremely new to Subaru's so I'm very unsure what the is the could be. Any help is greatly appreciated!
Regards
mpinto19k is offline
post #2 of 46 Old 09-30-2013, 11:15 AM
Haw1es's Avatar
Haw1es is more helpful than not
Yikes! That doesn't sound fun. I'm fairly new to subies too, and I'm sure someone will correct me if I'm wrong. If you're hearing a hissing sound, or it sounds like a leak somewhere is check the hoses that connect to your intercooler or turbo. Hopefully you just popped a hose off. Also if you have a full 100% vent to atmosphere BOV, you may want to change it to a recirculating one.
Just my $.02
Shane
2010 WRX
2014 F150
Haw1es is offline
post #3 of 46 Old 09-30-2013, 11:37 AM
Brockton's Avatar
Easiest route is have a boost leak test done at a shop, 20-40 bucks and you know exactly where the leak is, if I had to guess though, I'd guess around the intercooler and throttle body, it seems to be a common place for the couplers to slip. You can always get under the hood and look around for split hoses and loose fittings. If it was your turbo you would know it.
My TB hose came loose under redline acceleration btw.
the RIOT act likes this.
Brockton is offline
post #4 of 46 Old 09-30-2013, 12:35 PM
n8mcd is a helpful contributing member
Make sure you aren't burning oil.
n8mcd is offline
post #5 of 46 Old 09-30-2013, 01:10 PM Thread Starter
mpinto19k's Avatar
Ok ya I'm going to get in there and check all my hoses and everything and worst case get the boost leak done. Bad timing for this though, being that I'm in the military really didn't want to spend money I didn't have to being that my next pay check isn't guaranteed.
How can I be sure im not burning oil? Just check the level? I didn't see anything smoking.
Thanks for responses
post #6 of 46 Old 09-30-2013, 01:15 PM
General-Leo's Avatar
General-Leo is more helpful than not
I'm in the military as well what branch are you in? if you are NAVY I'm 90% sure navy federal said that they will cover everyone with an active duty checking account at least for this paycheck.
General-Leo is offline
post #7 of 46 Old 09-30-2013, 01:18 PM
LW_Black4's Avatar
The tell-tale sign of burning oil is blue smoke. If it's an issue, there will be lots of it, and you won't miss it. Otherwise, focus on the boost leak.
n8mcd likes this.
Laszlo - blue '04 WRX
Meet the turbocharged rally-bred Subaru WRX.
LW_Black4 is offline
post #8 of 46 Old 09-30-2013, 01:44 PM
Check the TB to IC coupling...like everyone else said. It's probably that or the y-pipe since you're a 2005 model.
post #9 of 46 Old 09-30-2013, 02:13 PM
boo-key's Avatar
Probably a leak but, for $hits and giggles try disconnecting the battery to reset the ecu .
n8mcd likes this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #10 of 46 Old 09-30-2013, 02:19 PM Thread Starter
mpinto19k's Avatar
Leo I'm active Army and use USAA so hopefully they will do the same.
Definitely no blue smoke.
Pretty sure I've figured it out. One of the bolts on the turbo is loose as shit! Like once revved up that bolt just jiggles and turns like it serves no purpose. I checked all the pipes and hoses and everything seems ok with that. Does that sound like it could be the problem? If so would I probably have to replace the gasket as well or just tighten it back up?
In the attached picture it is the bolt right below the grimmspeed wastegate
post #11 of 46 Old 09-30-2013, 02:43 PM
boo-key's Avatar
That is a grimmspeed wastegate bracket in the pic. The bolt under it is from turbo to downpipe which if leaking would cause a exhaust leak not boost leak. Probably still should be addressed though. you say its not building boost and sounds like garbage which leads me to suspect your external wastegate is stuck open.
turmic and Nathan21 like this.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #12 of 46 Old 09-30-2013, 03:05 PM
boo-key's Avatar
Easiest way to check this would be as follows. Start with a cool engine/exhaust so you don't burn yourself. Start the engine and feel the exit of the dumptube for exhaust flowing out of it at idle. After the exhaust and engine have warmed up see if the dumptube is hot to touch but don't burn yourself. At idle there should be no exhaust flowing out of this and it should be considerably cooler than the rest of the exhaust. The dumptube is that silver flexible looking pipe to the right of the turbo in the picture. Another way to check would be to actually take the wastegate apart and make sure the spring isn't broken or hung up.
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #13 of 46 Old 09-30-2013, 04:21 PM Thread Starter
mpinto19k's Avatar
Boo-key bear thanks for reply. I just checked that out and there is no exhaust coming out of the dumptube at idle and it is cool to the touch. Does that mean that the wastegate is stuck open then?
Also if that is the case will it be ok to drive home, I have to go about 20 miles and most of it will be in traffic going about 20-30 mph
post #14 of 46 Old 09-30-2013, 04:44 PM
boo-key's Avatar
That means its probably working properly. Hmmm
Adair
06' wrx tr
Phatbotti tuned!
boo-key is offline
post #15 of 46 Old 09-30-2013, 04:45 PM
That's a IWG block off plate. It should be holding the IWG closed. The EWG is on the UP or at least it should be. Lol. But, seriously though. You're looking for a pre-exhaust leak. The cold side of the turbo. Is that a stock turbo? Stock inlet? What are your mods besides the EWG?
