S.M.S Save my subbie! - Subaru WRX Forum
post #1 of 12 Old 08-10-2008, 09:25 AM Thread Starter
ImNASTI's Avatar
ImNASTI is an unknown
Send a message via Skype™ to ImNASTI
allright, so yesterday my friend and I spendt about 7 hours installing my new vf39, STI pinks, NGK plugs, STI TMIC, and a walboro fuel pump.
I tuned it with my COBB AP and after everthing was done, drove it about 5 miles, testing it out.
we had a problem with a spark plug wire comming loose and the car would misfire and run like crap, but it would still run.
other then that, i was hitting 18psi in 3rd and 4th, my target boost. (all the parts are used so i didn't think they needed too long to break in)
It was all good untill i was heading over to my girls house, and i came to a stop sign, when i went to hit the gas, there was nothing, and the RPM gauge just kept winding down. the car stalled, and then would not start, it will crank and crank, but it will not catch. I ended up having it towed back to my house, and now it sits in the drive way My friend thinks that maybe my computer got fried. Anyone have any insight, or at least something is should try? Please help!
ImNASTI is offline
post #2 of 12 Old 08-10-2008, 10:16 AM
zmanoside's Avatar
zmanoside is a helpful contributing member
Your friend might be right. I've heard recently from some protuners you have to be VERY careful when reflashing your ecu with the AP. Those little green connectors are VERY touchy, if they are bumped or touched while the ecu is being reflashed it can def fry your ecu.
12.7 @ 109
zmanoside is offline
post #3 of 12 Old 08-10-2008, 10:20 AM Thread Starter
ImNASTI's Avatar
its kinda strange that it would run for a while though isn't it?
ImNASTI is offline
post #4 of 12 Old 08-10-2008, 06:10 PM Thread Starter
ImNASTI's Avatar
anyone else?? anything?
ImNASTI is offline
post #5 of 12 Old 08-12-2008, 02:07 PM Thread Starter
ImNASTI's Avatar
It was the fuel pump. It was brand new and died within 7 miles, crappy.
but now everything is good, power feels good. My friend with an STi thinks its almost as fast as his
ImNASTI is offline
post #6 of 12 Old 08-12-2008, 02:26 PM
Wow, thats good it wasnt anything major. Sucks the fuel pump crapped out the quick though. Glad you got it figured out and its nothing crzy expensive or anything.
post #7 of 12 Old 08-12-2008, 03:28 PM
Yeah, glad to hear it was something less expensive then a ecu. Probably is close to his STI....just he has probably has some torque on you. That's all.
post #8 of 12 Old 08-12-2008, 04:21 PM
Man, must have been hard to isolate that. Kudos.
post #9 of 12 Old 08-13-2008, 12:25 PM
awd4life's Avatar
awd4life is an unknown
Yeah, I think that I would have had to cry a lot of tears before I would have thought that it was the brand new fuel pump. It is great that it wasn't anything terribly major.
awd4life is offline
post #10 of 12 Old 08-14-2008, 07:45 PM Thread Starter
ImNASTI's Avatar
just took the rex on a 600 mile road trip full loaded down with all my belongings. No problems, enough power to tow an entire trunk full of stuff, and two stuffed back seats with 2 adults in the front...
.....*tear*.........the little rex that could
ImNASTI is offline
post #11 of 12 Old 08-15-2008, 08:36 PM
wrxshotta's Avatar
wrxshotta is on thin ice
honestly how did you isolate it to the fuel pump lol wow props man props...good to hear its runnin nicee
wrxshotta is offline
post #12 of 12 Old 08-17-2008, 10:20 AM Thread Starter
ImNASTI's Avatar
I pulled the lines off the fuel filter and cranked it and saw that there was not pressure. so it just happened to be the first thing i tried. I didn't think it was going to start and then it fired right up.
Question. at low RPMs there is a high pitched fluttering sound. I thought it might have been the injectors, but after going above 3500 rpms, i cant hear it anymore. It could be the exhaust is just too loud but i think it goes away
ImNASTI is offline
