rough idle at cold temps/ o2 sensor issues - Subaru WRX Forum
post #1 of 17 Old 03-24-2012, 12:24 AM Thread Starter
rex2002's Avatar
ok 1st off ive been running stage 2 cobb map with all supporting mods for close to a year with no problems. no cels what so ever.i now have 2 cel's p0031( h025 heater control circuit low ,bank 1 sensor) & p1130 (front oxygen sensor circuit malfunction,open circuit). once i start the car when its cold it idles around 1300rmps, but it has rough idle to the point that it sounds like its going to die.after i drive it and it warms up a little the rmp range is back to normal,but i have a lot of stutter/hesitation when driving. can anyone help me with this issue.
rex2002 is offline
post #2 of 17 Old 03-24-2012, 12:22 PM
bad grocerygetter's Avatar
When was the last tune up? Mine was throwing some weird codes also when all I needed was a fuel filter.
Kevin.
bad grocerygetter is offline
post #3 of 17 Old 03-24-2012, 12:59 PM Thread Starter
rex2002's Avatar
just changed the oil less than 2 weeks ago,and my fuel filter is due to be replaced on 5/30. spark plugs were changed shortly after the car was flashed. i haven't changed the coolant in a while. also checked tranny fluid during oil change and it was in normal range,shifts fine. stage two map says i need a high-flow catalytic converter,but on my setup ive got no cats at all and had no cel issues at all. after a year of almost being at stage 2 would my no cat setup finally catch up to me and throw those codes. there's a protune shop with awd dyno that supports cobb about 2 hour drive from me. would it be smart to go get a pro tune to make a custom map with the no cat setup?
rex2002 is offline
post #4 of 17 Old 03-24-2012, 03:02 PM
I would if it were me, but I would make sure that the car has no other issues first. Hmmm... I dunno man. Let's wait and see who else chimes in. Keith? Kirt? What you guys think?
Kevin.
post #5 of 17 Old 03-24-2012, 10:07 PM
Could be a front 02 sensor...I'm not quite sure. I'd get it checked out to make sure its not something mechanical before I'd be thinking about getting a tune.
post #6 of 17 Old 03-25-2012, 12:34 AM Thread Starter
rex2002's Avatar
going to replace the front o2 sensor and clear the code and hope the code doesn't come back
rex2002 is offline
post #7 of 17 Old 03-25-2012, 08:11 AM
If that doesn't work try doing a data log when the car is acting up. Let us see what's going on. Maybe a video as well
Kevin.
post #8 of 17 Old 03-25-2012, 10:49 AM
Check this website out...it was a quick google search for the root cause of your P0031 heater control circuit low.
P0031 Oxygen (A/F) Sensor Heater Control Circuit Low (Bank 1 Sensor 1) - DTC Code
So, basically that is two CELs pointing the finger at your front 02 sensor.
post #9 of 17 Old 03-25-2012, 01:37 PM Thread Starter
rex2002's Avatar
ordered a new o2 sensor.ill post back my findings once i install it and clear the cel. thanks for the help everyone
@turmic that link was very helpful
rex2002 is offline
post #10 of 17 Old 03-25-2012, 10:29 PM
My front 02 Sensor crapped out about a year ago and was causing all sorts of problems. Its not a problem man...I hope it fixes your problem.
post #11 of 17 Old 03-30-2012, 08:06 PM Thread Starter
rex2002's Avatar
ok got the new o2 sensor in and the o2 code is now gone, but im still throwing p0031( h025 heater control circuit low ,bank 1 sensor) even with the cobb ecu code reset and no luck.. any other ideas what that p0031 code is,what can i do to fix it.
rex2002 is offline
post #12 of 17 Old 04-02-2012, 07:20 AM
^Did you buy an OEM o2 sensor?
Or a Bosch ?
post #13 of 17 Old 04-06-2012, 04:54 PM Thread Starter
rex2002's Avatar
no my dumb ass bought an o2 senor when i should of bought an air/fuel o2 sensor. just put the right sensor in and now no codes. while the car was riding like shit i was hitting 19lbs of boots on the stock tdo4 on a cobb stage 2 map.i guess with the air/fuel being jacked up it made the car pull a lot harder. i guess theres a little more wiggle room in that tdo4. is 19lbs safe on a tdo4. now that im back to the right air/fuel im back at 16lbs of boost.
rex2002 is offline
post #14 of 17 Old 04-06-2012, 05:58 PM
Safe for the turbo? Yeah, maybe. Right for the map you are on? No, not at all. Glad you are back to correct specs. It's said that anything over about 20 lbs and the td04 just becomes a flame thrower. Just out of its efficiency range.
Kevin.
post #15 of 17 Old 04-07-2012, 04:37 PM
Glad you figured it out
