rough and boggy engine at 3k rpms - Subaru WRX Forum
post #1 of 19 Old 10-26-2011, 08:39 PM Thread Starter
WRXInfantryGuy's Avatar
WRXInfantryGuy is an unknown
this is my first subaru wrx its a 2007 all stock with 85000 miles. i noticed that the engine starts sounding rough and boggy at 3k rpms in first and second gear, is this normal?
WRXInfantryGuy is offline
post #2 of 19 Old 10-26-2011, 08:47 PM
doesn't sound normal, do you have a Check Engine light on?
post #3 of 19 Old 10-26-2011, 08:56 PM Thread Starter
nope no check engine light. its sounds like its working really hard at 3k for first and second
post #4 of 19 Old 10-26-2011, 08:58 PM
did this just start?
post #5 of 19 Old 10-26-2011, 09:29 PM Thread Starter
its been like this for four days so as long as ive had it.
post #6 of 19 Old 10-26-2011, 09:32 PM Thread Starter
could it be pistons? or maybe fuel pumps or somthing?
post #7 of 19 Old 10-26-2011, 10:34 PM
Is all of your routine maintenance up to date?
Subaru maintenance schedules and new car break-in period- 2000 through 2009, links for 2010, 2011...
Spark plugs, fluids, filters, and whatnot?
post #8 of 19 Old 10-26-2011, 10:36 PM Thread Starter
im starting to think its a spun rod bearing. this sucks because i just bought the car! is it possible for it to be a rod if its only at 3k rpms?
post #9 of 19 Old 10-26-2011, 10:50 PM Thread Starter
i just drove the car to try to listen for the knocking noise and its more of a boggy noise that could be considered as a knock but it only happened in first gear at 3k.
post #10 of 19 Old 10-27-2011, 07:03 AM
^This
Get all this stuff done to rule out. Get the ECU read for codes, even if one isn't showing (they are stored sometimes).
You didn't hear anything on the test drive ? And JUST 1st gear at 3K ? Do you have anything to monitor the car with ?
post #11 of 19 Old 10-27-2011, 08:46 AM
Does it sometimes feel like it's going to stall going around turns kind of hard?
post #12 of 19 Old 10-27-2011, 04:36 PM Thread Starter
ok i figured out what the problem was it was rod bearings its still under warrenty so the dealer ordered an new block with 16k miles
post #13 of 19 Old 10-27-2011, 04:49 PM Thread Starter
and i never noticed it before because i had a baby in the car so i was shifting at 25k rpms i noticed it while i was driving to work i started shifting at 35k rpms and it started making that noise. its all ok now the problem is fixed.
post #14 of 19 Old 10-27-2011, 06:09 PM
No wonder it spun a rod bearing, shifting at 25,000 rpms isn't helping....lol
post #15 of 19 Old 10-27-2011, 07:31 PM
Man you need to call up the record books, thats some amazing engine work to get a H-4 to spin that high.
