Revving to high after flat battery - Subaru WRX Forum
post #1 of 3 Old 01-15-2012, 03:42 AM Thread Starter
I have been away for a week and when I returned my 2004 WRX had a flat battery. I charged the battery and now the car starts with no dramas at all however the idle revs are 2,000 rpm. Does anyone know what could be the problem and how I can fix it?
Mark1969 is offline
post #2 of 3 Old 01-16-2012, 05:58 AM
Try to plop another battery in it to see if it still does it. Did you take the battery to get tested?
There is a reason the battery went dead (faulty alternator perhaps)
post #3 of 3 Old 01-16-2012, 09:26 AM
More than likely your car is reving high because your ECU lost all of its realtime map data and its re-learning. It should happen the first time you drive it, but if it does it every day for the next couple of days then you have a problem.
