rear tires rubbing - Subaru WRX Forum
post #1 of 3 Old 06-28-2004, 09:05 PM Thread Starter
gunship64 is an unknown
Angry rear tires rubbing
I have a 03 wrx wagon. I bought some 17" konig rims with some 225/45 tires. My rear tires are rubbing in the outside fenders when I go around corners w/ bumps at about 30-45 mph. Or with people in the back. It feels like my rear suspension has alot more play then that of a sedan. How should I fix this. Please help.
gunship64 is offline
post #2 of 3 Old 07-08-2004, 10:18 PM
LilSix's Avatar
LilSix is an unknown
I'm not too sure about the wrx as I haven't bought my rims yet, butttttt, on my mazda6s I had the same problem. The problem is in the wheel offset. It is somewhere around a 50, so if you put a 42 offset like most rims are, you will have a rubbing problem. 2 choices. Get different rims with a proper offset, or roll your fenders.
LilSix is offline
post #3 of 3 Old 07-09-2004, 06:57 AM
Joe Boxer is an unknown
Send a message via AIM to Joe Boxer
easy solution...
stop hauling 300 lb hoochies in the back, the shaggin' wagon wasn't made for that.
like LilSix said, most likely the wheels you put on are an offset of 42. get some fiddies and you will be all set.
REMEMBER: No fat chicks, car will scrape.
Joe Boxer is offline
