Rattling noise - Subaru WRX Forum
post #1 of 3 Old 02-16-2004, 01:56 PM Thread Starter
Sleepr_Blu is an unknown
Unhappy Rattling noise
There seems to be a rattling noise when i let off the gas. I am not sure if it is the transmission or the heat shield. Someone help me...please!
Sleepr_Blu is offline
post #2 of 3 Old 02-16-2004, 03:40 PM
ozzyinnit is an unknown
sleepr blu,
Scoobs are renowned for noisy heat shields so i'd say remove heat shield, run until hot and see if noise is still present, is the noise a proper rattle(as in loose bolt noise) or is it more of a knocking noise, if it is then check your rear centre bush mounts( the two that look at you when you look at your suspension housing) as these are allways going on scoobs as they are rubber to metal ( better on 2003 onwards!!!),
Hope you get sorted mate,
ozzyinnit is offline
post #3 of 3 Old 02-16-2004, 06:35 PM Thread Starter
[QUOTE]Originally posted by ozzyinnit
sleepr blu,
[/QUOTE
It sounds more like a loose bolt. I am gonna have it checked out at a dealer. Thanks for your help ozzy!
