Rattle In 2nd Gear - Subaru WRX Forum
post #1 of 4 Old 04-06-2003, 07:36 PM Thread Starter
AMANDA is an unknown
Rattle In 2nd Gear
I HAVE A 02 WRX WITH 50K AND WHEN ITS IDLING THERES A TICKING NOISE COMIN FROM THE TRANNY, AND WHEN I PUSH THE CLUTCH IN IT STOPS, ALSO WHEN ITS IN 2ND GEAR IT MAKES A LOUD RATTLING NOISE LIKE SOMETHING IS REALLY LOOSE IN THE TRANNY.
AMANDA is offline
post #2 of 4 Old 04-10-2003, 03:41 PM
rexwagonee is an unknown
are the clutch and flywheel stock?
does the sound get louder at higher RPMs?
when was the last time you changed the transmission fluid?
have you installed an sti tranny mount?
rexwagonee is offline
post #3 of 4 Old 04-11-2003, 03:19 PM Thread Starter
i just found out it has broken teeth in the tranny. subaru wont cover it either. they are stripped just broken and subaru is telling me that is my fault that it broke, they called it abuse. i bought used with 40k.
AMANDA is offline
post #4 of 4 Old 04-11-2003, 03:40 PM
i replied to you about that in your other post. wish you luck getting it worked out.
