Old 06-13-2008, 11:56 PM   #1 (permalink)
03 CrazyTaxi's Avatar
Reputation: 03 CrazyTaxi is more helpful than not
Radiator issues
Ok, so I'm on my 3rd radiator. Apparently because I have an upgraded turbo and many other parts, my radiator can't handle the pressure and keeps blowing the radiator seals. That's according to the shop that I usually take the car to.
So my question is:
Is this really possible? Or is the shop trying to bs me?
Old 06-14-2008, 02:23 AM   #2 (permalink)
What type of radiator have you been using that keeps blowing? Or have you been trying a different one each time?
Old 06-14-2008, 06:45 AM   #3 (permalink)
Club Region: Gulf Coast
Reputation: pzr2874 is an unknown
It is possible since they work together. The pump circulates coolant from the turbo back to the radiator for cooling. 3 though ??
2007 WRX
Old 06-14-2008, 09:58 AM   #4 (permalink)
The radiator cap sets the pressure for the system.If you are running an STI or any aftermarket cap it raises the pressure from 1.1bar-1.3 bar.It will cause prblems with OEM type radiators with the plastic end tanks.
Aarg matey!
ECU Pirated by RomRaider
Online
Old 06-18-2008, 05:29 PM   #5 (permalink)
Ok, well the one that the shop put on is 16psi. That's around 1.1bar so that's not the problem. I can see if it was an 18 or 19psi cap but it's not.
Yeah, its an OEM that I've been popping the end caps on. Strange part is I'm still using the OEM hoses instead of silicone. They haven't expanded that I've noticed. Thought that would have happened before the end tanks...
Compression test came out within spec so not sure what's going on.
Old 06-18-2008, 06:36 PM   #6 (permalink)
So is it really seeing more pressure or overheating?Tons of people run turbos as big as 20G's on the stock core.
Aarg matey!
Online
Old 06-19-2008, 07:29 PM   #7 (permalink)
Well, the temp guage would always be centered. The only thing that I noticed was a puddle of coolant and water under the car. That's when I found the leak and called the shop that had replaced it.
Old 06-20-2008, 02:04 AM   #8 (permalink)
So hve you come up with what you are going to do or what to change out the stocker with?
Old 06-20-2008, 11:19 AM   #9 (permalink)
Are you sure the puddle wasn't from the overflow tank?Also try running a 66% water and 33% coolant mixture instead of a 50/50.
Aarg matey!
Online
Old 06-20-2008, 01:08 PM   #10 (permalink)
Hey Ron, shouldn't a 75/25 work as well or 80/20 ?
2007 WRX
Old 06-20-2008, 04:00 PM   #11 (permalink)
It technically would work better.Straight water would work the best over all as far as summer is concerned.I just recommend 66/33 because you can run it all year long.It basiclly comes down to your climate.
Aarg matey!
Online
Old 06-21-2008, 01:57 AM   #12 (permalink)
Paul is lucky enough to live in one of those places where he doesnt have to worry about the extremes colds like back east. (And I know they arent that extreme, but when the car disappears in the snow drift, you know.)
Old 06-21-2008, 11:53 PM   #13 (permalink)
Yep, I've run straight water since it started leaking. Still leaking.
I've decided to save up for a Koyo 2 row all aluminum welded radiator. That is want my mechanic recommended.
Old 07-07-2008, 02:28 AM   #14 (permalink)
Ok, so I should have a Mitsumoto 2 row all aluminum radiator and all 9 coolant hoses replaced with 3 ply yellow silicone Samco hoses by Friday
Along with all that comes a new ERZ bellmouth downpipe, GM BCS, and a Walbro 255.
